Battery for Pine64
(08-28-2016, 05:39 PM)MarkHaysHarris777 Wrote: hi, the converter you use needs to be at least a 2A rating continuous, and preferably 2.5A, but more importantly for this discussion, the 5v needs to be very clean.
... I am using the CPT converter which delivers a fairly clean 5v continuous at 2A. I also added a filter to the setup to smooth the noise which typically comes from a dc-dc converter. The problem is that the PineA64 will draw spikes of current from time to time and the 5v 'must' remain stable during those spikes.  A 2A supply is often not enough especially if the 5v is not clean (has ripples in it).  Take a look at the thread I posted earlier. My battery setup is running very well with the CPT converter and filter ( 5v @ 2A ).
Hi, thanks for the quick reply. I will check out your solution and see if it's something I want to try.again thanks.
Battery for Pine64 - by steve8939 - 08-21-2016, 06:45 PM
RE: Battery for Pine64 - by pfeerick - 08-21-2016, 08:48 PM
RE: Battery for Pine64 - by steve8939 - 08-28-2016, 05:30 PM
RE: Battery for Pine64 - by MarkHaysHarris777 - 08-22-2016, 07:13 PM
RE: Battery for Pine64 - by MarkHaysHarris777 - 08-28-2016, 05:39 PM
RE: Battery for Pine64 - by steve8939 - 08-28-2016, 07:15 PM
RE: Battery for Pine64 - by trondkj - 09-21-2016, 08:14 AM
RE: Battery for Pine64 - by lijinraj - 08-27-2017, 06:23 AM
  +LTS/SOPINE Raspberry Pi Piface2 board installed on a Pine64? coolio 0 3,388 11-26-2019, 11:39 AM
Last Post: coolio
  Can the Pine64 act as a bluetooth receiver? photojoe 7 13,449 11-04-2019, 02:26 AM
Last Post: Partymack711
  Battery Takes Forever To Charge Bluphire 5 12,364 01-04-2017, 06:43 PM
  Nexdock with Pine64 running RemixOS bartvvr 4 9,998 10-02-2016, 02:13 PM
