Battery for Pine64
(08-21-2016, 08:48 PM)pfeerick Wrote:
(08-21-2016, 06:45 PM)steve8939 Wrote: Hello, has anyone had any luck in powering the Pine64 using a battery? I used a pair of 18650's and a power converter, but it only powers up the down. The converter has a 1 amp rating with a 3 amp burst.
Need some more info mate. Like:
  1. What voltage is the converter set to? 5v?
  2. How have you got it connected to the pine? micro usb? euler bus?
  3. How are you turning it on? power button? plugging in?
  4. Probably not too important at this stage, but what image is it running (ubuntu, debian, android, etc)?
And yes, I have my pine64 running directly from a lipo battery without any issues, using the battery connector. Running it from the USB port via a booster shouldn't be an issue as long as its set at the right voltage. You'll want to make sure there's some sort of protection circuitry on the batteries to prevent them being under-discharged though.
Hello thanks for the response. I am using 2 TR 18650 5000mah 3.7 volt lipos in series connected to a voltage converter set to 5.2 volts its rated at 1amp continuous 3 amp burst. I am using android and connecting through the power connector next to the RTC battery connector. I am also using the touch screen.
Battery for Pine64 - by steve8939 - 08-21-2016, 06:45 PM
RE: Battery for Pine64 - by pfeerick - 08-21-2016, 08:48 PM
RE: Battery for Pine64 - by steve8939 - 08-28-2016, 05:30 PM
RE: Battery for Pine64 - by MarkHaysHarris777 - 08-22-2016, 07:13 PM
RE: Battery for Pine64 - by MarkHaysHarris777 - 08-28-2016, 05:39 PM
RE: Battery for Pine64 - by steve8939 - 08-28-2016, 07:15 PM
RE: Battery for Pine64 - by trondkj - 09-21-2016, 08:14 AM
RE: Battery for Pine64 - by lijinraj - 08-27-2017, 06:23 AM
  +LTS/SOPINE Raspberry Pi Piface2 board installed on a Pine64? coolio 0 2,457 11-26-2019, 11:39 AM
Last Post: coolio
  Can the Pine64 act as a bluetooth receiver? photojoe 7 10,080 11-04-2019, 02:26 AM
Last Post: Partymack711
  Battery Takes Forever To Charge Bluphire 5 9,348 01-04-2017, 06:43 PM
  Nexdock with Pine64 running RemixOS bartvvr 4 7,575 10-02-2016, 02:13 PM
