Battery for Pine64
(08-21-2016, 06:45 PM)steve8939 Wrote: Hello, has anyone had any luck in powering the Pine64 using a battery? I used a pair of 18650's and a power converter, but it only powers up the down. The converter has a 1 amp rating with a 3 amp burst.
Need some more info mate. Like:
  1. What voltage is the converter set to? 5v?
  2. How have you got it connected to the pine? micro usb? euler bus?
  3. How are you turning it on? power button? plugging in?
  4. Probably not too important at this stage, but what image is it running (ubuntu, debian, android, etc)?
And yes, I have my pine64 running directly from a lipo battery without any issues, using the battery connector. Running it from the USB port via a booster shouldn't be an issue as long as its set at the right voltage. You'll want to make sure there's some sort of protection circuitry on the batteries to prevent them being under-discharged though.
Battery for Pine64 - by steve8939 - 08-21-2016, 06:45 PM
RE: Battery for Pine64 - by pfeerick - 08-21-2016, 08:48 PM
RE: Battery for Pine64 - by steve8939 - 08-28-2016, 05:30 PM
RE: Battery for Pine64 - by MarkHaysHarris777 - 08-22-2016, 07:13 PM
RE: Battery for Pine64 - by MarkHaysHarris777 - 08-28-2016, 05:39 PM
RE: Battery for Pine64 - by steve8939 - 08-28-2016, 07:15 PM
RE: Battery for Pine64 - by trondkj - 09-21-2016, 08:14 AM
RE: Battery for Pine64 - by lijinraj - 08-27-2017, 06:23 AM
  +LTS/SOPINE Raspberry Pi Piface2 board installed on a Pine64? coolio 0 3,388 11-26-2019, 11:39 AM
Last Post: coolio
  Can the Pine64 act as a bluetooth receiver? photojoe 7 13,449 11-04-2019, 02:26 AM
Last Post: Partymack711
  Battery Takes Forever To Charge Bluphire 5 12,364 01-04-2017, 06:43 PM
  Nexdock with Pine64 running RemixOS bartvvr 4 9,998 10-02-2016, 02:13 PM
