Cannot flash the modem firmware
(09-15-2025, 04:33 PM)anonymous Wrote:
(09-15-2025, 12:50 PM)biketool Wrote:
(09-14-2025, 01:00 PM)anonymous Wrote: Hello
I cannot flash the modem firmware. I succeeded in flashing ADSP by using ADSP Version EG25GGBR07A08M2G_30.202.30.202 but when I run flashall (with or without sudo), it just displays "waiting for any device". I tried to run each command line one by one and this message appears when running "fastboot oem stay":
https://github.com/the-modem-distro/pine...s/flashall
How can I solve this problem?
I'm under Mobian bookwork, I'll switch to Mobian trixie when this problem is solved.
P.S: I'm going to upgrade the operating system first, it had worked with Mobian Trixie once for sure.
what type of sim does your pinephone (or PP pro) use?
remember you need to use sudo su and then execute the scripts as real root, just usng sudo will fail you.
I use the Pinephone (not the Pinephone Pro). Thank you for the tip, I used only sudo.
By the way, my upgrade from Mobian Bookworm to Trixie failed, I tried to use your suggestion, I use full disk encryption:
https://forum.pine64.org/showthread.php?...#pid112326
When I enter "resizepart 2 100%" and "print", the size of the boot partition doesn't change. Am I missing something obvious?
parted displays:
Number Start         End         Size        Type       File system Flags
1            8389kB    512 MB   503 MB   primary  ext4             boot
2            512 MB    31.0GB   30.5GB   primary
Should I use resize2fs -M?
OK it is important to know that you will probably end up with a softbricked modem when upgrading, it is just something to do with the sightly different firmware on the PPpro and maybe newer PPs.
It is no big deal though. the modem firmware page had the complete fix and it works for everyone I know of who has used it.
rely on this and not the git below https://themodemdistro.com/efs_recovery
https://github.com/the-modem-distro/pinephone_modem_sdk
Since we are in a modem thread, does everyone else get a very-warm to hot PPpro when making 3g voice calls? It gets uncomfortable and I don't want to think about the wasted battery.
Cannot flash the modem firmware - by anonymous - 09-14-2025, 01:00 PM
RE: Cannot flash the modem firmware - by biketool - 09-15-2025, 12:50 PM
RE: Cannot flash the modem firmware - by biketool - 09-16-2025, 02:54 AM
RE: Cannot flash the modem firmware - by Gumur - 09-16-2025, 07:43 AM
RE: Cannot flash the modem firmware - by biketool - 09-16-2025, 09:16 AM
  Logging modem dialout attempts biketool 2 1,843 04-11-2025, 02:47 AM
Last Post: vusra
  Modem wakes for incoming call, but too slow to answer the call dchang0 8 3,596 12-01-2024, 07:54 PM
Last Post: dchang0
  [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 freelectro 1 2,701 08-30-2023, 03:59 AM
Last Post: karensather
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 7,821 06-06-2023, 06:36 AM
Last Post: freelectro
  ModemManager debug mode? (Needed to flash modem) calinb 1 3,375 02-27-2023, 04:18 PM
Last Post: calinb
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 10,588 09-23-2022, 05:15 AM
  Firmware upgrade via fwupd user641 3 4,660 04-24-2022, 11:01 AM
Last Post: yehudac
  Biktorj's firmware user641 5 6,383 03-08-2022, 05:15 PM
Last Post: user641
  Phosh modem on/off effectiveness? Zebulon Walton 0 1,773 01-24-2022, 09:21 AM
  How to flash a µSD-Card with Balena Etcher walter1950 1 2,463 01-22-2022, 02:06 AM
Last Post: bcnaz
