Bare metal on Pinephone Pro
I would like to boot a bare metal program (that just starts and enters in an infinite loop) (asm+c) on my ppp thank to U-Boot, but U-Boot don't boot my program and blinks the multicolor led in red, and then shut down. What's wrong in my code ?
start.S
    .global start
start:
    msr        DAIFSet, #7
    bl        main
spin:    b        spin
spl.lds
ENTRY(start)
SECTIONS
    . = 0x02000000;
    . = ALIGN(4);
    .text :
        *(.text)
    . = ALIGN(4);
    .rodata : { *(.rodata*) }
    . = ALIGN(4);
    .data : { *(.data*) }
    . = ALIGN(4);
    .got : { *(.got) }
    _end = .;
    . = ALIGN(8);
    __bss_start__ = .;
    .bss_start (OVERLAY) : {
        KEEP(*(.__bss_start));
        __bss_base = .;
    .bss __bss_base (OVERLAY) : {
        *(.bss*)
        . = ALIGN(4);
        __bss_limit = .;
    .bss_end __bss_limit (OVERLAY) : {
        KEEP(*(.__bss_end));
    __bss_end__ = .;
main.c
* Tom Trebisky  12-31-2021
typedef volatile unsigned int vu32;
typedef unsigned int u32;
struct gpio {
    vu32 data;
    vu32 dir;
    u32 _pad0[2];
    u32 _pad1[8];
    vu32 ie;
    vu32 im;
    vu32 il;
    vu32 ip;
    vu32 is;
    vu32 ris;
    vu32 debounce;
    vu32 eoi;
    vu32 ext;
    u32 _pad2[3];
    vu32 sync;
#define GPIO0_BASE ((struct gpio *) 0xff720000)
#define GPIO1_BASE ((struct gpio *) 0xff730000)
#define GPIO2_BASE ((struct gpio *) 0xff780000)
#define GPIO3_BASE ((struct gpio *) 0xff788000)
#define GPIO4_BASE ((struct gpio *) 0xff790000)
#define GPIO_BASE GPIO0_BASE
#define LED_BIT        (8+3)
#define LED_PIN 24
#define LED_MASK 1<<LED_PIN
void main ( void ) {
    volatile int count = 100000000;
    while ( count-- )
Makefile
BOARD = rk3399
CROSS_COMPILE = aarch64-linux-gnu-
OBJS = start.o main.o
TARGET = $(BOARD).bin
# CFLAGS        :=    -g -Wall -Wextra -ffreestanding -fno-builtin -mlittle-endian
CFLAGS        :=    -g -Wall -ffreestanding -fno-builtin -mlittle-endian
CFLAGS        += -march=armv8-a+crc
CFLAGS        += -mtune=cortex-a53
CFLAGS        += -I.
LDFLAGS        :=    -Bstatic \
            -Tspl.lds \
            -Wl,--start-group \
            -Wl,--end-group \
            -Wl,--build-id=none \
            -nostdlib
CC            =    $(CROSS_COMPILE)gcc $(CFLAGS)
LD             =    $(CROSS_COMPILE)gcc $(LDFLAGS)
OBJCOPY            =    $(CROSS_COMPILE)objcopy
DUMP            =    $(CROSS_COMPILE)objdump
LOAD            =    tools/loader -h64
# This gives us dependencies in .d files.
# CFLAGS        += -MMD
# This gives us a map file.
# CFLAGS        += -Wl,-Map=$(BOARD).map,--cref \
.c.o:
    @echo " [CC]   $<"
    @$(CC) $< -c -o $@
.S.o:
    @echo " [CC]   $<"
    @$(CC) $< -c -o $@
all: install
#all: $(TARGET)
install: $(TARGET)
#     cp $(TARGET) /var/lib/tftpboot
$(BOARD).elf: $(OBJS)
    @echo " [LD]   $(BOARD).elf"
    @$(LD) $(OBJS) -o $(BOARD).elf
$(TARGET): $(BOARD).elf
    @#echo " [IMG]  $(TARGET)
    @$(OBJCOPY) -O binary $(BOARD).elf $(TARGET)
dis: $(BOARD).elf
    $(DUMP) -d $(BOARD).elf -z >$(BOARD).dis
fetch:
    cp ../USB_loader/loader tools
usb:  $(TARGET)
    $(LOAD) $(TARGET)
sdcard:  $(TARGET)
    $(LOAD) -o $(TARGET) | dd of=/dev/sdf seek=1 conv=fdatasync
.PHONY: clean
clean:
    rm -f *.o
    rm -f *.img
    rm -f *.elf
    rm -f *.bin
    rm -f *.map
    rm -f *.dis
Bare metal on Pinephone Pro - by alain - 08-19-2025, 07:58 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 12,796 10-20-2025, 07:01 AM
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 4 4,954 08-19-2025, 01:38 AM
Last Post: geometrylitegame12
Star FreeBSD developer build for PinePhone Pro teekay 1 1,424 05-03-2025, 11:02 AM
  freeBSD is booted on pinephone pro with console output zetabeta 5 2,943 04-18-2025, 12:56 AM
Last Post: teekay
  How to Clone Kali Linux to PinePhone Pro with Terabyte IFW TOF 2 2,584 02-26-2025, 02:15 AM
Last Post: TOF
  Anyone gotten latest Ubuntu Touch to work on PinePhone Pro? dchang0 4 3,716 12-22-2024, 04:21 PM
Last Post: dchang0
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 3,279 10-28-2024, 10:46 AM
Last Post: Jite
  tow-boot, just bought pinephone pro stratofall 4 3,089 07-30-2024, 03:43 PM
Last Post: stratofall
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 79,948 02-13-2024, 02:54 PM
Last Post: fxc
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 2,726 11-23-2023, 08:44 AM
Last Post: mburns
