New Install, apps start but don't show up on screen?!
Hi All,
New PinePhone Pro, put Mobian on it right away because I'm already using Debian on several R Pis, so its familiar. I put it on an SD card and BEFORE first boot it was a little tricky to get it to boot. Someone who knows more than me should capture that for us, I just stumbled into how to get it to boot the very first time. But once it had been through the first boot it shows up reliably in the U-Boot choices, so all good there.
And it comes up just fine and you can look around and see the apps and so forth. BUT, when an app is selected, you see it starting with appropriate looking visuals, but then when you expect the app to be open and ready to do something for you, all you get is the default screen background!
I tried four or five apps, including settings and the tour/tutorial, and you can see that they're running because the higher-level window manager works fine. So you can swipe this way and that and see stuff. BUT, you can't actually get into any app!
HELP!
Thanks,
RT
New Install, apps start but don't show up on screen?! - by RT3 - 07-18-2025, 04:30 PM
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 290 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 6,658 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 680 11-04-2025, 04:13 AM
Last Post: JChdeL
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,344 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 8,255 08-05-2024, 06:12 AM
Last Post: baptx
  Waydroid install instructions end up attempting to use wrong URLS to aquire .debs chainingsolid 1 4,348 04-26-2024, 04:56 PM
Last Post: zetabeta
  Phoch Trixie weekly install seems nice reTestability 0 1,951 03-10-2024, 08:47 AM
Last Post: reTestability
  Keyboard not popping up on QT apps 3x5co 1 2,568 02-08-2024, 11:45 PM
  Screen auto-rotation sensitivity mdk 0 1,910 12-26-2023, 06:08 AM
Last Post: mdk
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 8,465 11-22-2023, 11:46 AM
Last Post: aLoop100o
