PBP does not start from postmarket OS image burnt to sd card
#21
(03-10-2025, 08:16 AM)tophneal Wrote:
(03-07-2025, 06:54 PM)wdt Wrote: is it a 1 or 2 partition image?
uboot will be looking for either boot,scr or extlinux.conf or aarch64.efi  (only 1)
any of these must be in correct location
as well, sometimes the paths in extlinux.conf can be wrong, paths are  in relation to itself,
I had that happen only last week from my inherited son's pbp
OP is trying to boot an install SD of TowBoot
yes exactly @tophneal  @wdt I'm trying to install TowBoot from spi, but I get a u-boot prompt (if I interrupt the boot - otherwise it's the never-stopping message/question from the photo above) whichever way the emmc switch is flipped...
thanks!!
RE: PBP does not start from postmarket OS image burnt to sd card - by zkajdan - 03-10-2025, 11:56 AM
  What's a good image to use now? [tutorial help as well] frank_philip 40 16,650 07-18-2025, 07:28 PM
Last Post: Dendrocalamus64
  Pinebook Pro upgrading from the factory image yamsoup 12 11,146 02-22-2024, 04:02 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 4,155 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Postmarket OS passcode ionmich 1 1,670 06-30-2023, 02:25 PM
Last Post: jakfish
  2TB SD Card Write Errors jiacovelli 3 2,950 06-02-2023, 06:13 PM
  Bootloader: SD card boot quirks crazyquark 1 2,333 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Unable to make a bootable microSD card myself600 15 11,860 09-27-2022, 01:45 PM
Last Post: myself600
  postmarketOS/Alpine edge image for the Pinebook Pro MartijnBraam 74 168,300 08-24-2022, 02:06 PM
Last Post: petersen77
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 20,124 08-18-2022, 11:26 PM
Last Post: calinb
  Debian/unstable SD card rescue image vajak 4 6,523 10-28-2021, 02:53 PM
Last Post: vajak
