PBP does not start from postmarket OS image burnt to sd card
#19
Yes, the switch is mislabeled, think short (clock) disabled, so there is a emmc clock working since not shorted
you have a uboot prompt, type help
also.... mmc help
that version of uboot is either not scanning mmc or card is not setup right
(or not a good card)
try writing the image to a usb stick, try BOTH usb sockets
is it a 1 or 2 partition image?
uboot will be looking for either boot,scr or extlinux.conf or aarch64.efi (only 1)
any of these must be in correct location
as well, sometimes the paths in extlinux.conf can be wrong, paths are in relation to itself,
I had that happen only last week from my inherited son's pbp
RE: PBP does not start from postmarket OS image burnt to sd card - by wdt - 03-07-2025, 06:54 PM
  What's a good image to use now? [tutorial help as well] frank_philip 40 20,661 07-18-2025, 07:28 PM
Last Post: Dendrocalamus64
  Pinebook Pro upgrading from the factory image yamsoup 12 12,524 02-22-2024, 04:02 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 5,250 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Postmarket OS passcode ionmich 1 1,932 06-30-2023, 02:25 PM
Last Post: jakfish
  2TB SD Card Write Errors jiacovelli 3 3,268 06-02-2023, 06:13 PM
  Bootloader: SD card boot quirks crazyquark 1 2,587 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Unable to make a bootable microSD card myself600 15 13,163 09-27-2022, 01:45 PM
Last Post: myself600
  postmarketOS/Alpine edge image for the Pinebook Pro MartijnBraam 74 179,815 08-24-2022, 02:06 PM
Last Post: petersen77
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 23,225 08-18-2022, 11:26 PM
Last Post: calinb
  Debian/unstable SD card rescue image vajak 4 7,920 10-28-2021, 02:53 PM
Last Post: vajak
