PBP does not start from postmarket OS image burnt to sd card
(02-20-2025, 01:13 AM)zkajdan Wrote: Do you have an idea what I could do? Thanks again!!
I think you need to get Tow-Boot on the SPI.
I am not sure pine64 uses the wiki anymore, I think they moved everything to "documentation"
From the RK3399_boot_sequence
  1. loading from NOR flash on SPI1
  2. loading from NAND flash on SPI1
  3. loading from eMMC
  4. loading from SD on the SDMMC controller
  5. bringing up the OTG0 USB controller in device mode and accepting control transfers to load programs
The eMMC may have an issue booting. You may need to Disable the eMMC so you can boot off the SD. Once booted off the SD, I personnally would try to get Tow-Boot on the SPI.
RE: PBP does not start from postmarket OS image burnt to sd card - by mikehenson - 02-20-2025, 09:09 AM
  What's a good image to use now? [tutorial help as well] frank_philip 40 22,156 07-18-2025, 07:28 PM
Last Post: Dendrocalamus64
  Pinebook Pro upgrading from the factory image yamsoup 12 12,990 02-22-2024, 04:02 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 5,433 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Postmarket OS passcode ionmich 1 2,013 06-30-2023, 02:25 PM
Last Post: jakfish
  2TB SD Card Write Errors jiacovelli 3 3,396 06-02-2023, 06:13 PM
  Bootloader: SD card boot quirks crazyquark 1 2,671 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Unable to make a bootable microSD card myself600 15 13,590 09-27-2022, 01:45 PM
Last Post: myself600
  postmarketOS/Alpine edge image for the Pinebook Pro MartijnBraam 74 184,107 08-24-2022, 02:06 PM
Last Post: petersen77
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 23,953 08-18-2022, 11:26 PM
Last Post: calinb
  Debian/unstable SD card rescue image vajak 4 8,047 10-28-2021, 02:53 PM
Last Post: vajak
