Improved battery life with TLP daemon
In one of the recent Manjaro system updates TLP was mentioned as an option to power-profiles-daemon to manage battery life for the Pinebook Pro.
On the Pinebook Pro the TLP power management gives subjectively better battery performance over power-profiles-daemon. Especially sleep lasts over night without problems. My PBP is one of the earliest (second batch, I believe) and yet with TLP the battery performance is great.
The downside is that the PBP user interface feels slightly more sluggish in KDE Plasma. Everything seems to be a bit slower than it used to be. This might be different in a simpler (tiling) window manager. The TLP documentation mentions that their power management suits light users best (writing, etc).
However, the battery performance feels much improved.
If you are interested:
## Install TLP
$ sudo pacman -S tlp
You will be asked to uninstall **power-profiles-daemon**, say yes.
There is an additional package `tlp-rdw`, check in the docu if you want that.
To enable the service use (and reboot)
$ sudo systemctl enable tlp.service
## Config
I have used this config change to improve performance when power is plugged in:
Edit /etc/tlp.conf and un-comment and update:
CPU_ENERGY_PERF_POLICY_ON_AC=performance
You can check the config with:
tlp-stat --config
tlp-stat -p
tlp-stat -p -v
If you want you can set `CPU_ENERGY_PERF_POLICY_ON_BAT` to `performance` as well.
Here is a link to the TLP documentation
# power-profiles-daemon
To switch back to the **power-profiles-daemon**:
$ sudo pacman -S power-profiles-daemon
$ sudo systemctl enable power-profiles-daemon
And here is the link to some power-profiles-daemon documentation
Improved battery life with TLP daemon - by Surehand53 - 12-30-2024, 07:46 AM
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 3,668 03-15-2025, 01:47 AM
Last Post: frank_philip
  Battery gauge issue (mainline kernel) lfourquaux 4 7,955 05-22-2021, 02:43 PM
Last Post: jiyong
  eMMC frequently not found by Linux kernel (especially on low battery) v-man 14 24,731 05-14-2021, 01:18 PM
Last Post: djhnsn
  Battery charge threshold xNix 1 3,377 04-17-2021, 07:13 AM
Last Post: Damon
Question Manjaro arm + sway - battery indicator broken mfashby 6 10,051 02-20-2021, 04:07 AM
Last Post: mfashby
  Possible battery and performance improvement xehartnort 4 8,053 11-09-2020, 12:26 AM
Last Post: rimaille
  Manjaro - No battery info after plugged in AlecM 4 8,392 09-16-2020, 08:34 PM
Last Post: zer0sig
  Manjaro XFCE: Vastly improved experience with Picom (Compton) compositor jichu4n 2 16,992 07-20-2020, 01:43 PM
Last Post: jichu4n
  get battery status on the command line rossk 2 7,804 04-04-2020, 09:25 PM
Last Post: rossk
  i3status issues reading battery status dummy 9 17,009 01-31-2020, 08:27 AM
Last Post: C_Elegans
