Installing r2kaw and Tow-Boot to the SPI
(12-18-2024, 05:13 AM)dukla2000 Wrote:
(12-17-2024, 04:59 PM)ethical_haquer Wrote: I tried using it with U-Boot, but U-Boot couldn't find the pmOS installation I have on the eMMC.
rk2aw includes its own flavour of uboot (as does Tow-Boot): I had problems with pmOS and rk2aw as pmOS wasn't happy to have its boot directory in the same partition as /. So if I did a "default" pmOS where /boot had its own partition, and didn't bother with extlinux stuff, rk2aw happily picked up the EFI hooks and it loaded fine. However it kept randomly rebooting so I went with arch.
(12-17-2024, 04:59 PM)ethical_haquer Wrote: ...
I'm just surprised that no one has tried using Tow-Boot with rk2aw before. It should be possible, seeing as Tow-Boot is based off U-Boot.
I am perplexed as to why you would want to? Both Tow-Boot & rk2aw are "facilitators" between the board startup firmware and (their own flavour of) uboot. As such they flash LEDs, make disks available over USB and give some options which is your OS of choice for the day. I prefer rk2aw as it (better) supports multiple OSs on each disk.
I was under the impression that rk2aw was a loader for boot-loaders.
When you flash rk2aw to the SPI and there are no boot-loaders present on the SPI, eMMC, and microSD, rk2aw won't do anything.
And I was able to flash Tow-Boot to the microSD, and rk2aw to the SPI, and it worked. rk2aw would start up, and after pressing the power key Tow-Boot would load pmOS.
But that was not ideal, as having Tow-Boot on the microSD made it so I couldn't test out other installations easily.
How do you like Arch on the PPP?
RE: Installing r2kaw and Tow-Boot to the SPI - by ethical_haquer - 12-18-2024, 08:17 AM
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 6,716 02-25-2025, 08:27 AM
  tow-boot installation problem techariah 4 6,234 12-04-2024, 10:32 AM
Last Post: zetabeta
  How can boot from MicroSD after replacement of the main board u-kidjp 6 4,413 11-08-2024, 09:14 PM
  tow-boot, just bought pinephone pro stratofall 4 3,740 07-30-2024, 03:43 PM
Last Post: stratofall
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 89,920 02-13-2024, 02:54 PM
Last Post: fxc
Brick Recovery without Tow Boot b34ux 10 8,871 02-02-2024, 07:07 PM
Last Post: reky
  What to do if your PinePhone Pro does not boot fxc 19 40,095 09-10-2023, 03:19 AM
Last Post: fxc
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 5,163 02-18-2023, 06:14 PM
Last Post: fxc
  create tow boot .img fox95 6 8,281 10-21-2022, 11:40 AM
Last Post: fox95
  No display on early boot after Manjaro update robocone 0 1,948 07-07-2022, 05:47 AM
Last Post: robocone
