Mobian, Suspend, and Audio Playback
I have had a pocket linux device in use since around Y2k starting with a Sharp Zaurus SL-5500 on to an Openmoko, then the N900.
One of the most important purposes of these devices was to play audiobooks when driving, cycling, working, or riding public transportation.
On all other devices I was able to get at least 5-8 hours of audiobook playback minimum along with other uses of the device, even with the Openmoko which like the Pine devices didn't have a major corporate Linux lab supporting the effort.
The pinephone(and pro) under mobian gives me around 3 hours maximum as suspend also kills off audio playback.
This severely limits my use of the PP if I cannot provide external power.
I know there are several ways to except the hardware audio acceleration chip from suspend and buffer only the audio stream as well as waking only one of the smaller CPUs for a fraction of a second to do a disk read and reload the audio buffer.
I am not sure how it was done on the N900 but I am sure someone on the forum has better insight into a power saving way to keep a streaming audio app working even when the system is in suspend, even if it is a lower level system hack.
<edit>
For example I can go most of the day dropping to ~80% battery if I don't use my phone much, I can still reliably receive calls and SMS but have it set to suspend after 1 minute. Same Mobian Trixie install drops to 30-40% after 2 hours if I set suspend to 30 minutes but blank the screen so I can listen to an audiobook on the bus/train. Once the 30 minutes are up if I have not touched the phone the audio playback will stop and I have to restart the Cozy(flatpak install) audiobook app to get it's audio to work.
Mobian, Suspend, and Audio Playback - by biketool - 12-11-2024, 12:56 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,440 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,692 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,735 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,128 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 272,287 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,902 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,436 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,852 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 2,844 04-29-2025, 02:10 PM
Last Post: mdk
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,953 01-15-2025, 08:08 PM
