Modem wakes for incoming call, but too slow to answer the call
(11-29-2024, 07:13 PM)zetabeta Wrote:
(11-29-2024, 04:53 PM)dchang0 Wrote: Hi, everyone--
For the first time, I've got two cellular phone lines and am able to play more with the PinePhone Pro.
I called the PPP running Mobian, and it woke properly from sleep, and the modem also woke properly, but it wakes so slowly that the incoming call has gone to voicemail without ever ringing. It does say "Missed call" on the lock screen afterward.
If the PPP is already awake, it rings and receives the call just fine, so all I need to figure out is how to get the modem to wake fast enough to receive the call.
Any tips are appreciated. I plan on updating Mobian to the latest package versions tomorrow. It's been many months since I last powered on the PPP, so whatever it is running now is old.
I also will apply any modem firmware updates if there are any newer ones.
If updating is a bad idea, please let me know.
Thanks!
i don't usually use suspend. but i tested sending sms mesaage to suspended pp pro with mobian. it waked up quickly and received sms. but modemmanager crashed afterwards. mobian is recently updated trixie.
i probably need to make further tests.
updating firmware is tricky question. do you use https://github.com/the-modem-distro/pinephone_modem_sdk or stock https://github.com/Biktorgj/quectel_eg25_recovery ?
if stock, i don't recommend 30.20x.xx.xxx series. 30.007.30.007 is the latest i would suggest.
if sdk, latest is the best, but you have to choose appropriate adsp image.
i installed this version https://github.com/Biktorgj/quectel_eg25...203.30.203 one of my pp regular without major issues. still no recommendations for 30.20x series.
Thanks for your help! Upgrading the firmware from Biktorgj's 30.006.30.006 to Biktorgj's 30.203.30.203 seems to have solved the problem. The modem still goes to sleep, but it wakes up fast enough for the call to ring. I did not upgrade from bookworm to trixie.
RE: Modem wakes for incoming call, but too slow to answer the call - by dchang0 - 12-01-2024, 01:40 PM
Exclamation Cannot flash the modem firmware anonymous 8 8,989 10-26-2025, 11:27 AM
Last Post: anonymous
  Logging modem dialout attempts biketool 2 1,844 04-11-2025, 02:47 AM
Last Post: vusra
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 7,547 08-05-2024, 06:12 AM
Last Post: baptx
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 7,845 06-06-2023, 06:36 AM
Last Post: freelectro
  ModemManager debug mode? (Needed to flash modem) calinb 1 3,385 02-27-2023, 04:18 PM
Last Post: calinb
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 6,380 12-01-2022, 09:18 AM
Last Post: traut
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 10,619 09-23-2022, 05:15 AM
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 5,412 06-02-2022, 07:16 AM
Last Post: arkadione
  Vibration motor buzzes uncontrollably with call waiting Zebulon Walton 2 3,168 05-28-2022, 07:32 PM
  Glacially slow system updates on Mobian - waiting on boot 20m - 1h bujiraso 5 6,359 03-01-2022, 10:06 AM
Last Post: bujiraso
