How-To: Remote Control Your Phone from Desktop via VNC
(10-13-2025, 10:39 AM)powerflow Wrote:
(10-10-2025, 06:25 AM)biketool Wrote:
(03-05-2025, 06:18 AM)Kevin Kofler Wrote: The Phosh Wayland compositor (phoc) uses wlroots, which is why it works with wayvnc.
SO I have something based on stripped ubuntu 24.04 and echo $XDG_SESSION_TYPE says x11 for my computer and I use tigerVNC viewer.  I used to get video from the PPp running Mobian trixie and now I get the grey on theVNC but I can use it for input if I can see the phone's screen.
I am not sure if wlroots requires a change in the config of the VNC server on the PPp?
hi, no solution but just remarks: looking up the problem there are lots of reasons why wayvnc may show a gray screen. one of the principal ones is that mobian's user (usually 'mobian') is not in the 'video' users group by default. unfortunately, "sudo usermod mobian -aG video" neither fixes the vnc problem, nor the other great problem of mobian that keeps it short of daily driving (for some people): the camera. No matter which camera app is used - related because the video group addition was suggested as a fix for both of these problems.
must be something in the setting of wlroots or wayvnc - strange that no error or warning appears at all, just gray screen (and apparently works in other distros that use phosh).
This is a regression since wayvnc works on bookworm, the image even rotates when the pinephone is rotated. I found 4 groups with user mobian on bookworm but not on trixie (render, video, dialout, and input) and did sudo usermod for each one by one logging out then logging back in. Nothing changed for the wayvnc even after a reboot.
As to no error, when I start wayvnc in trixie, I get:
"Warning: ../src/output.c: 300: Output DSI-1 power state failure"
RE: How-To: Remote Control Your Phone from Desktop via VNC - by j_s - 10-14-2025, 10:46 AM
  Jami on the Pine phone ? bcnaz 8 11,862 06-09-2025, 04:17 PM
Last Post: j_s
  is there an progam to forward calls and texts to my desktop dallytaur 2 4,452 11-01-2023, 04:55 AM
Last Post: Samurai_Crow
  Article: NuttX RTOS for PinePhone: Feature Phone UI in LVGL, Zig and WebAssembly lupyuen 64 46,487 09-09-2023, 09:49 AM
Last Post: WhiteHexagon
  Article: NuttX RTOS for PinePhone: Phone Calls and Text Messages lupyuen 2 3,306 05-03-2023, 05:03 PM
Last Post: lupyuen
  [Stupid Question] Where is the phone camera software?! newusername 5 5,862 10-10-2022, 03:58 AM
Last Post: newusername
  Control HBIAS through a linux OS twiclo 0 1,776 10-04-2022, 03:20 PM
Last Post: twiclo
Question New user/phone here - initial update issues sexywheat 2 3,367 06-29-2022, 04:27 PM
Last Post: sexywheat
  Which apps can I run on this phone? poppyhodler 2 4,337 06-07-2022, 12:18 PM
Last Post: jenniferjohn12
  Phone Operation which SW Realease (mute funtion)? scrwbigtek 0 1,636 05-25-2022, 07:35 AM
Last Post: scrwbigtek
  First time pine phone user Matt73 3 4,627 03-10-2022, 02:04 AM
Last Post: Matt73
