New PinePhone user issues
sudo pacman -Qqtq > list.txt
sudo pacman -R - < list.txt
This did not go well for me on a new PinePhone Beta. After one run of this, on the next attempt I experienced `user is not in the sudoers file`, which makes further work difficult.
New PinePhone user issues - by greenpineuser - 08-23-2024, 12:45 PM
RE: New PinePhone user issues - by Peter Gamma - 08-30-2024, 11:14 PM
RE: New PinePhone user issues - by jakfish - 08-31-2024, 01:26 PM
RE: New PinePhone user issues - by Peter Gamma - 09-01-2024, 01:52 AM
RE: New PinePhone user issues - by n13931n - 11-13-2024, 01:25 PM
RE: New PinePhone user issues - by jakfish - 09-01-2024, 09:37 AM
RE: New PinePhone user issues - by emilianojay - 12-19-2024, 09:47 PM
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 13,841 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 2,406 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 3,143 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 3,334 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 5,482 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 6,445 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 14,721 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 3,291 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 44,808 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 5,767 05-09-2022, 08:29 AM
Last Post: ragreenburg
