New PinePhone user issues
I'm not going to be able to help you with the modem, as i don't use it. On the other hand, here are a few explanations for the update problems that should definitely solve your current and future problems.
The regular ‘core’ and ‘extra’ repositories (‘community’ is now deprecated) contain packages that are sometimes removed to be replaced by their equivalents from further development, but renamed differently. And there have been a lot of these over the last few months, I myself have encountered the same difficulties updating my Manjaro with Plasma mobile system. These problems also occur when changing from the regular branch to the test branch. I'm going to be fairly precise in my explanations, as I've noticed that these problems recur on several forums.
OK, let's go!
The packages that cause conflict problems are ‘foreign’ packages, which are therefore not present in the regular repositories, as opposed to the packages that exist in these regular repositories, which are ‘native’ packages. It should also be noted that packages installed from the AUR are also ‘foreign’ packages. The list of ‘foreign’ packages can be obtained as follows:
sudo pacman -Qm
You should recognize in this list the names of packages that have caused you problems, in principle.
All foreign packages can be safely removed, as they are not necessary for the regular operation of the system. And if one of them is nevertheless necessary (as a dependency, for example) pacman will give you a warning. But don't confuse a warning related to a conflict with other ‘foreign’ packages that you're going to remove anyway (some depend on each other), with warnings related to a conflict with ‘native’ packages. That's why you need to remove the whole list of ‘foreign’ packages at once. To avoid wasting time recopying the names of all the packages on a very long line, here's how to use an intermediary file :
sudo pacman -Qmq > list.txt
(the lower-case ‘q’ is used to create the list without the package version number, as this would cause problems)
and then :
sudo pacman -R - < list.txt
If required, the list of files (list.txt) produced by the ‘sudo pacman -Qmq > list.txt’ command can then be edited with a text editor, for example to remove packages installed by the user from the AUR, otherwise they will have to be reinstalled. (This have to be done before using the command ‘sudo pacman -R - < list.txt’, of course).
Finally, you need to clean up the system by removing all orphaned dependencies that are no longer required by other packages. To do this, the list can be obtained using the following command:
sudo pacman -Qdt
You can in the same way use a file list.txt to make things easier:
sudo pacman -Qqtq > list.txt
These last two commands should be repeated several times, until pacman returns an error because the entry is mute (because the list is empty). Deleting a dependency does not delete the dependency of the dependency, this is the reason (other methods exist, I like this one because I can see how my system is evolving).
And one last piece of advice: for dbus, ‘dbus-broker-units’ is the recommended choice in archlinux and it's also the one I've made, everything works fine on my pinephone.
I hope I've been able to help you as much as possible.
Best regards.
New PinePhone user issues - by greenpineuser - 08-23-2024, 12:45 PM
RE: New PinePhone user issues - by Peter Gamma - 08-30-2024, 11:14 PM
RE: New PinePhone user issues - by jakfish - 08-31-2024, 01:26 PM
RE: New PinePhone user issues - by Peter Gamma - 09-01-2024, 01:52 AM
RE: New PinePhone user issues - by TuxUnderTheArch - 09-01-2024, 05:29 AM
RE: New PinePhone user issues - by n13931n - 11-13-2024, 01:25 PM
RE: New PinePhone user issues - by jakfish - 09-01-2024, 09:37 AM
RE: New PinePhone user issues - by emilianojay - 12-19-2024, 09:47 PM
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 13,841 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 2,406 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 3,143 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 3,334 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 5,482 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 6,445 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 14,737 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 3,293 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 44,808 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 5,767 05-09-2022, 08:29 AM
Last Post: ragreenburg
