How to boot from SD card in PPP
(08-02-2024, 09:40 AM)joespodie Wrote: I put that SD card in the Pinephone Original ... The Postmarket OS /Phosh. Man it works fantastic. It found the SIM card on the first boot and it had never failed to find and make and receive calls. It awesome. So then I switch the SD card to the Pinephone Pro and it will not boot from the SD card. It turns out only the original pinephone boots by default to the SD card, the Pro version does not. Why?
The original PinePhone and PinePhonePro require different images (operating systems) to be loaded. PostmarketOS made for the PinePhone will not work on the Pro. You will need to reflash the correct OS for the Pro before inserting it into the Pro.
The PinePhonePro boot orders changes depending on the boot loader. Start with tophneal link above.
How to boot from SD card in PPP - by joespodie - 08-02-2024, 09:40 AM
RE: How to boot from SD card in PPP - by tophneal - 08-02-2024, 10:35 AM
RE: How to boot from SD card in PPP - by mikehenson - 08-02-2024, 02:49 PM
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 2,427 08-18-2025, 06:15 PM
  No rk2aw boot menu jebez 7 2,886 07-09-2025, 07:12 AM
Last Post: mikehenson
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 13,931 03-13-2025, 08:40 PM
Last Post: pcb
  PinePhone doesn't boot anymore lapin 3 2,864 09-13-2024, 10:09 AM
Last Post: lapin
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 3,694 02-17-2024, 04:04 AM
Last Post: fxc
  Can i reinstall the os with an image using ubuntu? without having an sd card? PineBetter 16 13,788 08-29-2023, 08:41 AM
Last Post: fxc
  Mobian + tow boot + emmc flash = boot loop spropine 4 6,369 12-31-2022, 09:14 AM
Last Post: mburns
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 6 7,188 11-20-2022, 05:58 AM
Last Post: wibble
  Tow-Boot issue Barugon 1 2,899 10-22-2022, 03:22 AM
Last Post: AndrewBlackmiller
  pinephone pro boot: kernel image not aligned on 64k boundary kmerfeld 2 4,472 08-15-2022, 10:35 AM
Last Post: ajaso
