problem with debian emmc boot
(07-24-2024, 08:32 PM)bits Wrote: Earlier this month, Debian 12 bookworm updated the Linux kernel to 6.1.0-23-arm64 (Debian 6.1.99-1 from 2024-07-15).  Rock64 boards upgraded to this Stable release kernel hang during boot after logging failure of mmc_select_hs200 to switch the eMMC bus width to 8:
Other hints in that changelog?
Thank you for responding and providing so much info.
The cause for this seems to be coming together as I also had similar boot problems with current rock64 armbian images.
Now I'm wondering if its possible to perhaps find a release candidate (as mentioned in the linked archlinuxarm thread) kernel and drop it on the emmc to get this working. I'm guessing that the dtb somehow matches the kernel version so maybe that would be required too. Of course, then some further intervention would probably be necessary once the patched/fixed kernel becomes available in the standard repos. I'm not entirely familiar yet how to configure linux boot on boards like this since nearly 100% of my experience is on x86 hardware.
A quick look at that changelog looking for (e)mmc related changes shows quite a few. Your hypothesis about changes meant for other rockchip boards impacting rk3328 functionality seems increasingly plausible. As for how to mitigate and eventually fix this problem, I'm not entirely sure yet. If this is a known problem, then perhaps there are already fixes being worked on upstream. I will try to investigate this further to find out more.
EDIT: It took a little while for my post to get approved so your latest response covers the questions and thoughts I had here. Thanks again for all your help and insights into this issue.
problem with debian emmc boot - by G4zCDzWb - 07-23-2024, 12:41 PM
RE: problem with debian emmc boot - by G4zCDzWb - 07-24-2024, 09:28 AM
RE: Debian Linux 6.1.20-23 fails eMMC boot - by G4zCDzWb - 07-25-2024, 10:38 AM
RE: problem with debian emmc boot - by bits - 07-25-2024, 08:41 AM
RE: problem with debian emmc boot - by Boia11 - 07-25-2024, 04:02 PM
RE: problem with debian emmc boot - by Boia11 - 07-27-2024, 04:47 AM
RE: problem with debian emmc boot - by G4zCDzWb - 07-27-2024, 06:18 AM
RE: problem with debian emmc boot - by bennofs - 07-27-2024, 12:04 PM
RE: problem with debian emmc boot - by Boia11 - 07-30-2024, 05:41 AM
RE: FIXED problem with debian emmc boot - by bits - 11-01-2024, 04:32 PM
  PXE Boot example? lewis 7 14,343 10-08-2025, 06:51 AM
Last Post: LewisHenderson
  How to boot an older, working kernel bits 0 1,746 11-01-2024, 04:43 PM
Last Post: bits
  Debian installation via sd card oaFJSADBKV 0 1,624 10-12-2024, 10:24 AM
Last Post: oaFJSADBKV
  arch rock64 does not boot nemnob 1 3,516 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  How to update/compile Debian 12.5? Wizardknight 3 3,660 03-29-2024, 05:01 AM
Last Post: gedas07
  Rock64 won't boot dstallmo 0 2,608 12-27-2023, 10:34 AM
Last Post: dstallmo
  Rock64 Debian 11 (Bullseye) install problem jbize 15 18,098 10-12-2023, 05:14 PM
Last Post: tpaul
  Disabling last mount time check on boot acwest 0 1,685 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 11,444 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 2,261 06-27-2022, 06:52 PM
