3 days in, slow/stuck or no boot.
#26
(09-03-2024, 06:34 PM)KC9UDX Wrote: Whatever happens, do not give up hope.  I might be wrong but I seriously suspect that every serious PBP user has been through exactly what you're experiencing.
Thank you for the supportive responses, @wdt and @KC9UDX
1. I've used Linux for approx 5 years on Windows or former Windows laptops. With respect to PBP, I flashed images for PBP on Windows on this older Lenovo Thinkpad and then I changed over to Debian. Used Etcher on both and Disks on Debian. Am not necessarily a Linux newbie, but am not a techie, either. Am not entirely sure that I flashed some software images well- that is, archiving, extracting etc. so that I will go over the Getting Started version of Pine64, again. https://pine64.org/documentation/Introdu...g_started/
2. I use Pine 64 store's USB adapter for emmc module and it seems to work well https://pine64.com/product/usb-adapter-for-emmc-module/ I  put pmOS on a new emmc module and put Armbian on the older emmc module and then changed and put pmOS on it because pmOS was the only OS/distro that seemed to work.
3. I use Sandisk Mobilemate+ reader and IOgear reader, usually in USB 2 port. Also, I use either Sandisk 32 G A1 sd card, Lexar 64 g or Kingston 32. Tow-boot is on a Transcend 8G card. For USB sticks, I found that Kingston or Sandisk worked.
4. I left the PBP battery unplugged overnight  and pressed recovery, power off for about a minute each, after trying Tow-boot, sd cards with pmOS. As well, I tried a few suggestions from this 2 year old thread specifically ayufan's uboot erase and uboot flash. Nothing worked. https://www.reddit.com/r/PINE64official/...r_good_or/  https://github.com/ayufan-rock64/linux-m...t/releases
Yes, I tried sds with emmc removed or turned off--- is turning it on really turning it off. I read somewhere on here that it is this way?-
Nothing worked and it is very disheartening. The red power light at the barrel port is on when plugged in with charger.
This is a lovely laptop and I wanted to use it with either Abiword or Libre Office, to watch videos (yes, I did so already and the display or screen is nice); listen to music on Elisa and some more and learn a bit more about Linux and such laptops.
Although I am aware it is nearly impossible to totally brick PBP, I am not sure what else to do. Thanks again.
3 days in, slow/stuck or no boot. - by lgmpbp2 - 06-30-2024, 10:04 AM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 06-30-2024, 06:41 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 07-01-2024, 09:16 AM
RE: 3 days in, slow/stuck or no boot. - by wdt - 07-01-2024, 09:26 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 07-26-2024, 09:56 AM
RE: 3 days in, slow/stuck or no boot. - by wdt - 07-26-2024, 11:33 PM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 07-27-2024, 07:30 AM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 08-31-2024, 07:09 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 09-01-2024, 08:33 AM
RE: 3 days in, slow/stuck or no boot. - by wdt - 09-01-2024, 05:12 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 09-02-2024, 11:33 PM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 09-03-2024, 06:34 PM
RE: 3 days in, slow/stuck or no boot. - by lgmpbp2 - 09-04-2024, 10:23 AM
RE: 3 days in, slow/stuck or no boot. - by wdt - 09-04-2024, 12:23 PM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 09-04-2024, 09:23 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 09-04-2024, 11:07 PM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 05-24-2025, 05:01 PM
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 707 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 1,208 10-21-2025, 09:08 AM
  upgrading u-boot--what version? where to get it? bsammon 14 15,348 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 10,978 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 3,703 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 4,785 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,339 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 7,507 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,316 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 8,980 12-15-2023, 02:11 PM
