3 days in, slow/stuck or no boot.
#24
Probably the voltage select problem is from pmOS, that's a guess, if I was betting, that's where I would put money
You have a emmc adapter, is it usb or sd? If sd, do you have a card reader?
The reason manjaro does not boot is likely that the emmc (one of the partitions) needs a fsck (do both)
(the other problem is manjaro's uboot is still defective months later, has problems booting sd, this is a long standing problem)
I assume you have another computer, probably a windows box?
Do you know how/are capable of making this (other computer) do a "linux live boot"?
Try an armbian image on a sd card
Ordinarily the pbp cannot boot from usb, that you could was because you had tow-boot on SPI
The boot loader in the cpu is really limited, only searches SPI, emmc, sd (in that order) to find idbloader,
which initializes memory and then has enough (mem) to load uboot, uboot then alters boot search order
Likely, when you wiped SPI, the next idbloader (and uboot) is on emmc, manjaros uboot which has problems booting sd
And that is likely why you get no boot, I bet if you try to boot with the emmc removed, everything would just work
If my guess is right, then reinstall towboot to SPI
3 days in, slow/stuck or no boot. - by lgmpbp2 - 06-30-2024, 10:04 AM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 06-30-2024, 06:41 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 07-01-2024, 09:16 AM
RE: 3 days in, slow/stuck or no boot. - by wdt - 07-01-2024, 09:26 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 07-26-2024, 09:56 AM
RE: 3 days in, slow/stuck or no boot. - by wdt - 07-26-2024, 11:33 PM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 07-27-2024, 07:30 AM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 08-31-2024, 07:09 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 09-01-2024, 08:33 AM
RE: 3 days in, slow/stuck or no boot. - by wdt - 09-01-2024, 05:12 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 09-02-2024, 11:33 PM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 09-03-2024, 06:34 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 09-04-2024, 12:23 PM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 09-04-2024, 09:23 PM
RE: 3 days in, slow/stuck or no boot. - by wdt - 09-04-2024, 11:07 PM
RE: 3 days in, slow/stuck or no boot. - by KC9UDX - 05-24-2025, 05:01 PM
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 728 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 1,242 10-21-2025, 09:08 AM
  upgrading u-boot--what version? where to get it? bsammon 14 15,452 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 11,008 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 3,713 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 4,810 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,367 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 7,549 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,326 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 9,029 12-15-2023, 02:11 PM
