External monitor on PBP Docking Deck
(06-06-2024, 04:52 PM)bsammon Wrote:
(05-31-2024, 01:51 PM)ColoBill Wrote: I've seen a couple other posts but all are from 3 years ago or so.  I just thought there might some newer thoughts.  For hardware I've tried with a USB-C to HDMI adapter I had around and I also bought the Pinebook Pro Docking Station (PBP-DOCK11) years ago and had no luck with it either.
I looked into this a few years back.  I didn't put a lot of effort into trying it though.  My recollection of my impressions of what people were saying on the forum back then are:
USB-C-to-HDMI adaptors won't work, because the PBP hardware doesn't support HDMI-over-USB.  The PBP hardware will work with a USB-C-to-Displayport adaptor, however.
Most USBC-HDMI cables on the market use an internal DP->HDMI converter chip, so the computer is still outputting via DisplayPort alt mode. (Direct HDMI over USB-C is a thing, but most laptops / cables don't implement it.)
(06-06-2024, 04:52 PM)bsammon Wrote: I didn't do as much research about the Docking Station, but I vaguely remember getting the impression that it contains its own video chip in it, so it's kinda like adding a second video card to your computer.  If that's correct, then guides/advice about configuring X/Wayland to switch video outputs probably wouldn't work, because you actually want to configure X/Wayland to switch video devices if you're using the docking station.
That would require the PBP to support Thunderbolt/USB4, which I don't think it does.
RE: External monitor on PBP Docking Deck - by Pavlos1 - 06-07-2024, 02:44 AM
  How to use original PINEBOOK Pro USB-C Docking Deck with my PBP? Comoq 2 4,771 05-30-2022, 02:45 AM
Last Post: jpalus
  Issues with External Display After Recent Update reundo 0 3,307 11-18-2021, 06:37 PM
Last Post: reundo
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 5,122 11-17-2021, 10:02 AM
Last Post: Phillip Bell
  External DVD/CD MIchael 22 38,078 03-07-2021, 03:49 PM
Last Post: ab1jx
  External Monitor Recommendations SteveSquatch 1 3,764 02-17-2021, 08:23 AM
Last Post: Arwen
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 3,326 01-17-2021, 01:50 PM
Last Post: BananaPekan
  [split] Change password from external media James Good 11 23,066 07-23-2020, 02:42 PM
  USB-C to 4k monitor: right 1/3 not working robt 4 8,975 07-12-2020, 02:46 PM
Last Post: robt
  Battery draining with external power while under load? RndmNmbr 17 31,255 06-24-2020, 08:33 PM
Last Post: Syonyk
  Audio jack and external mic? johns 5 12,215 06-10-2020, 12:42 PM
