External monitor on PBP Docking Deck
(05-31-2024, 01:51 PM)ColoBill Wrote: I've seen a couple other posts but all are from 3 years ago or so.  I just thought there might some newer thoughts.  For hardware I've tried with a USB-C to HDMI adapter I had around and I also bought the Pinebook Pro Docking Station (PBP-DOCK11) years ago and had no luck with it either.
I looked into this a few years back.  I didn't put a lot of effort into trying it though.  My recollection of my impressions of what people were saying on the forum back then are:
USB-C-to-HDMI adaptors won't work, because the PBP hardware doesn't support HDMI-over-USB.  The PBP hardware will work with a USB-C-to-Displayport adaptor, however.
I didn't do as much research about the Docking Station, but I vaguely remember getting the impression that it contains its own video chip in it, so it's kinda like adding a second video card to your computer.  If that's correct, then guides/advice about configuring X/Wayland to switch video outputs probably wouldn't work, because you actually want to configure X/Wayland to switch video devices if you're using the docking station.
RE: External monitor on PBP Docking Deck - by bsammon - 06-06-2024, 04:52 PM
  How to use original PINEBOOK Pro USB-C Docking Deck with my PBP? Comoq 2 3,041 05-30-2022, 02:45 AM
Last Post: jpalus
  Issues with External Display After Recent Update reundo 0 1,928 11-18-2021, 06:37 PM
Last Post: reundo
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 3,342 11-17-2021, 10:02 AM
Last Post: Phillip Bell
  External DVD/CD MIchael 22 28,509 03-07-2021, 03:49 PM
Last Post: ab1jx
  External Monitor Recommendations SteveSquatch 1 2,487 02-17-2021, 08:23 AM
Last Post: Arwen
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 2,268 01-17-2021, 01:50 PM
Last Post: BananaPekan
  [split] Change password from external media James Good 11 17,021 07-23-2020, 02:42 PM
  USB-C to 4k monitor: right 1/3 not working robt 4 6,836 07-12-2020, 02:46 PM
Last Post: robt
  Battery draining with external power while under load? RndmNmbr 17 24,106 06-24-2020, 08:33 PM
Last Post: Syonyk
  Audio jack and external mic? johns 5 9,016 06-10-2020, 12:42 PM
