PineTab Bluetooth
Hello all,
I was wondering if anyone had a fix to the following problem I ran into when setting up WIFI and Bluetooth functionality on the PineTab. I got through the WIFI setup without issue and it works great, but when running the following to setup Bluetooth:
sudo pacman -S bluez-deprecated-tools
sudo -i
echo ifname:bt cmd:BT_ON > /dev/bes2600
rfkill unblock bluetooth
hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep
hciconfig hci0 up
exit
sudo systemctl enable bluetooth
i run into an error right after running hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep
the error is as follows:
hciattch -s 1500000 /dev/ttyS1 any 1500000 flow nosleep
Can't get port settings: Input/output error
Can't initialize device: Input/output error
I did see the one resolution using UART but it did not work, plus the main use of setting up the Bluetooth was to use Bluetooth mouse and barcode scanner.
if anyone has a fix, or an idea when this may be fixed it would be greatly appreciated.
Kernel: 6.8.6-danctnix2-1-pinetab2
PineTab Bluetooth - by PimpDiCaprio - 05-29-2024, 11:11 AM
RE: PineTab Bluetooth - by elix - 07-18-2024, 12:30 PM
RE: PineTab Bluetooth - by elix - 07-20-2024, 08:03 PM
RE: PineTab Bluetooth - by spaesani - 11-01-2024, 09:30 AM
RE: PineTab Bluetooth - by spaesani - 11-02-2024, 05:08 AM
RE: PineTab Bluetooth - by Kevin Kofler - 11-02-2024, 11:46 AM
  Pinetab-V boot rescue anoduck 2 1,463 10-21-2025, 12:58 AM
Last Post: anoduck
  Any updates on Bluetooth for PineTab 2? BluetoothBroke 1 2,048 08-05-2025, 06:38 AM
  Bricked Pinetab 2 vatin 6 4,881 06-06-2025, 08:46 AM
Last Post: maxaltepo
  Gentoo on Pinetab istewart 0 1,929 01-26-2025, 08:21 PM
Last Post: istewart
  Pinetab-V Upgrade WrVLink 0 2,081 12-14-2024, 02:30 AM
Last Post: WrVLink
  bluetooth adapter? elix 3 3,284 11-03-2024, 01:45 PM
Last Post: elix
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 22,216 02-28-2024, 05:03 AM
Last Post: Surehand53
Wink Screen protector for PineTab 2 vatin 0 2,766 11-18-2023, 01:31 AM
Last Post: vatin
  PineTab 2 (arm64) thoughts and questions acruhl 7 10,117 09-01-2023, 01:13 PM
Last Post: acruhl
  PineTab 2 Dead Screen Kramey 16 17,360 08-12-2023, 05:44 PM
Last Post: Kramey
