Need help in understanding Yocto and U-boot build process for Star64
[quote pid="122119" dateline="1713890250"]
1. How did he/you guys find the U-boot partition map? I have seen the JH7110 Boot User Guide, but I haven't been able to figure out how U-boot mentions the partition sizes in their documentation.
2. I couldn't quite find where StarFive mentions that their drivers are not compatible with the newer 6.1xx Linux kernel, forcing @Fishwaldo to use the 5.1xx kernel. Ideally, one would be able to download the source tree and place the patches in the tree to compile it with bitbake in Yocto, yes?
[/quote]
You found the right doc but not everything is documented.
Regarding emmc/sd card:
BootROM loads from the GPT partition with type ID 2E54B353-1271-4842-806F-E436D6AF6985.
Upstream OpenSBI loads the second partition but you can do anything you want if you compile your own.
Upstream U-Boot is still looking for the right way to do a standardized boot - again, it's up to you.
Search for extlinux.conf in the U-Boot docs if your interested.
I've collected some information in this script:
https://github.com/yogo1212/arch-linux-s..._image#L52
You should be able to create an image using your own OpenSBI and U-Boot:
ROOTFS_IMG=.. UBOOT_ITB=.. UBOOT_SPL=.. ./compile_image /dev/mmcblk0
Just remember to give U-Boot something to work with (e.g. /boot/extlinux/extlinux.conf)
RE: Need help in understanding Yocto and U-boot build process for Star64 - by yogo1212 - 06-05-2024, 04:29 PM
  Battery Life on Latest InfiniTime Build? evelynwang 0 1,811 06-03-2025, 10:26 PM
Last Post: evelynwang
  Star64 distro overview October 2023 tantamount 7 6,549 01-11-2025, 09:12 AM
Last Post: gounthar
  star64 bootable images, u-boot, sbi, forum? hexdump 5 5,561 11-27-2024, 11:13 AM
  Star64/Starpro64 kernel building global 0 1,582 10-04-2024, 08:36 PM
Last Post: global
  [Star64] UART activity stopped yogo1212 0 1,503 02-11-2024, 04:34 PM
Last Post: yogo1212
  Star64 Mechanicals nbxmike 4 4,859 01-16-2024, 04:35 AM
Last Post: oilumiun12
  Armbian and AltLinux for Star64 (RISC-V) balbes150 28 20,840 11-24-2023, 06:26 AM
Last Post: balbes150
  [Article] Star64 JH7110: Experiments with OpenSBI (Supervisor Binary Interface) lupyuen 0 1,656 10-28-2023, 06:55 PM
Last Post: lupyuen
  [Article] Star64: Strange Workaround for TFTP Timeout in U-Boot Bootloader lupyuen 0 1,790 10-05-2023, 07:22 PM
Last Post: lupyuen
  star64-image-minimal-star64-2.1 & X fonts tantamount 0 1,442 10-02-2023, 07:02 PM
Last Post: tantamount
