Using the internet
(09-11-2016, 10:46 AM)tomarneson Wrote: The top area of the screen does show internet communication action, both send and receive at low rates of a few hundred bytes per second.
I'd need to see a screenshot/pic to be sure, but the top area from the screen is probably showing network traffic, rather than internet traffic...
IRC chat is probably the best way to work on this, as to work this issue out further someone will need to go through your network config files and setup with you, as it sounds like it is connecting to your wireless / local network fine (and if you ping 10.0.0.1 if that is still your gateway it should respond, and you may even be able to browse to it if there is a configuration page there), but for some reason isn't resolving anything past that. There is also the possibility that the gateway address is wrong, which is why the pine64 isn't getting on the internet.
Using the internet - by tomarneson - 08-02-2016, 11:09 AM
RE: Using the internet - by MarkHaysHarris777 - 08-02-2016, 11:22 AM
RE: Using the internet - by tomarneson - 08-12-2016, 01:27 PM
RE: Using the internet - by MarkHaysHarris777 - 08-12-2016, 05:23 PM
RE: Using the internet - by tomarneson - 08-13-2016, 08:25 AM
RE: Using the internet - by MarkHaysHarris777 - 08-13-2016, 01:24 PM
RE: Using the internet - by mypineme - 08-26-2016, 04:05 PM
RE: Using the internet - by tomarneson - 09-01-2016, 01:34 PM
RE: Using the internet - by mypineme - 09-01-2016, 04:43 PM
RE: Using the internet - by tomarneson - 09-07-2016, 06:56 PM
RE: Using the internet - by psychedup - 09-08-2016, 12:35 PM
RE: Using the internet - by tomarneson - 09-11-2016, 10:46 AM
RE: Using the internet - by pfeerick - 09-11-2016, 06:57 PM
RE: Using the internet - by mark1205 - 09-17-2016, 05:32 AM
RE: Using the internet - by tomarneson - 10-12-2016, 02:35 PM
