Recovery without Tow Boot
(01-07-2024, 01:07 AM)b34ux Wrote:
(01-06-2024, 06:04 PM)apink Wrote: Have you tried re-installing towboot?
https://tow-boot.org/devices/pine64-pinephonePro.html
https://github.com/Tow-Boot/Tow-Boot/releases
I have tried, however once I get Towboot on an SD card, I can't get my PPP to boot. No matter what I do I get a black screen and a steady green LED until I power it off. I can't seem to get my device to boot to a stage where I can then install Towboot, or any other software for that matter.
A week ago I tried to reinstall Tow-Boot using an SD card and also couldn't boot it. Then I realized, I made a mistake and I flashed the whole .tar.xz to the SD. There was an spi.installer.img file in the archive which should be used to flash to SD.
Than I had troubles to write to the SPI (a red screen with some error messages showed up). It helped to purge everything from EMMC (plugged via USB to Notebook and zeroed using dd command). After I was able to write new Tow-Boot.
Recovery without Tow Boot - by b34ux - 01-05-2024, 12:42 PM
RE: Recovery without Tow Boot - by apink - 01-06-2024, 06:04 PM
RE: Recovery without Tow Boot - by b34ux - 01-07-2024, 01:07 AM
RE: Recovery without Tow Boot - by jezek - 01-07-2024, 11:42 AM
RE: Recovery without Tow Boot - by shulamy - 01-06-2024, 10:54 PM
RE: Recovery without Tow Boot - by b34ux - 01-07-2024, 01:08 AM
RE: Recovery without Tow Boot - by apink - 01-07-2024, 03:03 PM
RE: Recovery without Tow Boot - by b34ux - 01-07-2024, 07:03 PM
RE: Recovery without Tow Boot - by apink - 01-07-2024, 09:26 PM
RE: Recovery without Tow Boot - by reky - 02-02-2024, 06:57 PM
RE: Recovery without Tow Boot - by reky - 02-02-2024, 07:07 PM
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 3,610 02-25-2025, 08:27 AM
  Installing r2kaw and Tow-Boot to the SPI ethical_haquer 10 2,803 12-19-2024, 05:22 PM
Last Post: dukla2000
  tow-boot installation problem techariah 4 3,667 12-04-2024, 10:32 AM
Last Post: zetabeta
  How can boot from MicroSD after replacement of the main board u-kidjp 6 1,921 11-08-2024, 09:14 PM
  tow-boot, just bought pinephone pro stratofall 4 1,966 07-30-2024, 03:43 PM
Last Post: stratofall
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 70,408 02-13-2024, 02:54 PM
Last Post: fxc
  What to do if your PinePhone Pro does not boot fxc 19 31,366 09-10-2023, 03:19 AM
Last Post: fxc
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 3,604 02-18-2023, 06:14 PM
Last Post: fxc
  create tow boot .img fox95 6 5,947 10-21-2022, 11:40 AM
Last Post: fox95
Question Recovery/Live image? Greendrake 0 1,480 07-18-2022, 02:09 AM
Last Post: Greendrake
