pinephone 3 ideas
(11-29-2023, 11:59 AM)aular Wrote: 1. 12 nano meter processor, to help power management of course maybe especially.
i don't know precise details of manufacturing process. general view is, smaller the process is more efficient cpu is. i'm not sure it is in all cases. battery life is important though. basically, longer battery life is more crucial than cpu power.
(11-29-2023, 11:59 AM)aular Wrote: 2. esim for travel. replace sim card alot and put it in new spot or do away with the sim card altogether.
i don't think esim is a good idea. physical sims have some advantages, like swappable and removable, and if it is nano-sim, it is already quite small. esim is like installable system, once installed then it is there. installation process by modem chip may not be strait forward, although it is done by modem chip rather than phone o.s..
in my area, some operators charge every esim card installation, i wonder why.
(11-29-2023, 11:59 AM)aular Wrote: 3. lcd display 1080p
yes, but physical size needs to be bigger as well. also for battery.
(11-29-2023, 11:59 AM)aular Wrote: 4. 6.1 bezzel less display
i would go bigger direction, although key reason is bigger battery.
(11-29-2023, 11:59 AM)aular Wrote: 5. maybe some dust and water resistance like galaxy s5 with galaxy s7 waterproofing plugs
if phone is possible to open, i don't think phone will have good water resistance. in a limited degree it's probably possible.
(11-29-2023, 11:59 AM)aular Wrote: 6. sharper camera, maybe take from iphone x camera
camera may have those driver issues, which may limit choices.
(11-29-2023, 11:59 AM)aular Wrote: 7. 5g and maybe possible satalite bands, even of not possible to be used right now, haave for later
satellite bands, could you specify further?
if you refer to microwave bands in nr5g, they will come in the future. microwave bands coverage is quite small, they are useful for some, but near useless for others.
current implementation of nr5g is non-standalone. i think nr modules are slightly too expensive at the moment. however when standalone mode becomes more available, i probably change my mind.
if you refer to actual satellite communication, i don't think is a good idea, few users use it, and device has some unnecessary hardware modules.
https://en.wikipedia.org/wiki/5G_NR_frequency_bands
pinephone 3 ideas - by aular - 11-29-2023, 11:59 AM
RE: pinephone 3 ideas - by zetabeta - 11-30-2023, 12:40 AM
RE: pinephone 3 ideas - by aular - 11-30-2023, 07:57 AM
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 313 04-11-2024, 03:10 PM
  Where PinePhone Pro are Made Tony90 1 605 01-18-2024, 09:20 AM
  using Zoom on Pinephone andrew907 5 1,276 12-09-2023, 01:26 AM
Last Post: crocspot
  Does pinephone allow you to repair your own device as easily as fairphone? unix21311 3 2,043 11-06-2022, 10:37 PM
Last Post: Harolddavies0
  can i install mobian on pinephone? luofeiyu 2 1,359 10-15-2022, 07:31 AM
Last Post: user641
  Does the pinephone have hardware kill switches located on the outside of the phone? unix21311 2 1,854 10-03-2022, 05:53 AM
Last Post: unix21311
Sad New PinePhone Mobian Weekly Image... No Boot photon 1 1,197 09-27-2022, 07:00 AM
Last Post: olyavi
  used PinePhone Mobian CE or PineTab CelynRollins 1 1,667 01-11-2022, 06:31 AM
Last Post: collierreinhold
  Are you OK with the size of the PinePhone? guenther 14 8,578 12-16-2021, 12:12 AM
Last Post: zetabeta
  I SHOULD NOT HAVE PURCHASED THE PINEPHONE Scooterman 5 4,692 12-09-2021, 06:52 AM
Last Post: ryo
