bookworm vs trixie discussion for mobian in pinephone regular.
So, to have this documented here in case the Manjaro forum ever goes down or deletes the old thread:
Kevin Kofler Wrote:For the last couple weeks, people had been complaining about being unable to understand what I was saying on my PinePhone during phone calls (no matter who initiated the call). I could usually hear the other end very well, but not the other way round. (As I was told later, the problem was that the voice had some bizarre, hard-to-describe echo-type effect that made it pretty much unintelligible, no matter what microphone volume I set in the Plasma Mobile settings GUI.)
So, after a painful experience today where I was trying to call several people and none understood more than a tiny fraction of what I said, I had a debugging session in the evening with my mother, involving her calling me while we were both at home, and me playing around with alsamixer settings (from my desktop over SSH to the PinePhone, because the alsamixer TUI is much easier to operate that way).
Thankfully, I found the culprit pretty quickly (it was actually the first knob I tried): The Mic 1 Boost setting. For some reason, this was set to the maximum 100. I found that when I toned it down to some arbitrary value (it ended up at 45), the other end could understand me much better. Then I tried toning it down all the way to 0 and that made it even better.
This leads to the “public service announcement”: If you have an original PinePhone, you will want to set Mic 1 Boost to 0. Having it set to 100 makes for horrible sound for the other end of phone calls. For me, the setting was remembered once set, I did not have to explicitly save it somehow.
To locate the setting, either run alsamixer and use the F6 key and the resulting popup to switch from the virtual PulseAudio device to the real hardware where the setting is, or (especially if you are on the device and do not have a physical keyboard with an F6 key plugged in) run alsamixer -D hw:0 to get to the hardware device directly. Then use the cursor key to the right until the cursor is on Mic 1 Boost and the cursor key down to set its volume to 0. (Cursor keys can also be found in the special key row above the virtual keyboard in QMLKonsole.)
RE: bookworm vs trixie discussion for mobian in pinephone regular. - by Kevin Kofler - 02-05-2024, 05:45 PM
  trixie update poll questions suggestions j_s 5 452 10-22-2025, 07:14 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 35 57,692 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,735 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,128 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 272,240 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 1,902 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,436 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,852 05-06-2025, 02:19 AM
  troubleshooting sleep/wake button on trixie biketool 5 2,492 05-04-2025, 08:11 PM
  mobian calamares fail merom 2 2,844 04-29-2025, 02:10 PM
Last Post: mdk
