Installation from serial console
What board are you trying to install to?
The Woodpecker serial adapter normally works well, but with the Quartz64 Model B it doesn't work (on revision 1.4).
The Debian Installer does work on certain boards it supports, but you need to use (and concatenate) the matching SDcard image. And during installation you need to make sure the first 16MB aren't used, or it won't be able to boot into the installed system. But the d-i does work over serial.
Installation from serial console - by oieza67 - 10-29-2023, 03:16 AM
RE: Installation from serial console - by shulamy - 10-29-2023, 05:46 AM
RE: Installation from serial console - by oieza67 - 10-29-2023, 09:48 AM
RE: Installation from serial console - by wdt - 10-30-2023, 09:48 AM
RE: Installation from serial console - by oieza67 - 10-31-2023, 06:53 AM
RE: Installation from serial console - by wdt - 10-31-2023, 09:08 AM
RE: Installation from serial console - by diederik - 10-31-2023, 12:13 PM
RE: Installation from serial console - by oieza67 - 01-06-2024, 11:04 AM
  [Article] Star64 JH7110 + NuttX RTOS: RISC-V PLIC Interrupts and Serial I/O lupyuen 0 1,639 08-01-2023, 06:48 PM
Last Post: lupyuen
  Serial Connection via SOcket CAT dustfinger 0 2,626 05-21-2020, 09:16 AM
Last Post: dustfinger
