Solid Model/Accurate Blueprint
(01-24-2016, 02:49 PM)Atomkinder Wrote: Saw some mention of dimensions in the 'Cases and Enclosure Question' thread, but I'm hoping for a nominal dimension solid model if possible, or at least a good print to work from. I'm a machinist by trade and want to try a few enclosure designs and the one REV B drawing is only for outer board dimensions which isn't going to do it. I want to be able to design and machine aluminum cases with integrated standoffs and the like.
Will a non-STL* model be available sometime soon? I would like to start designing before the board arrives in March.
*(hopefully something like a STEP or IGES solid model, or dare I say SolidWorks)
 try this:
https://grabcad.com/library/pine64-a64-db-2gb-rev-b-1
(04-13-2016, 09:29 AM)w1ntermute0 Wrote: If it helps anyone I threw together a rough CAD model, it's located here (see photo in attachment):
http://www.3dcontentcentral.com/parts/do...alogid=171
This is all based on measurements I took off my board, so don't get mad if you use it and your holes don't line up or whatever, but I tried to be as accurate as possible.  Let me know if you see any corrections needed.
Enjoy.
wm
this is also available thanks
Solid Model/Accurate Blueprint - by User 563 - 01-24-2016, 02:49 PM
RE: Solid Model/Accurate Blueprint - by User 563 - 02-01-2016, 10:11 PM
RE: Solid Model/Accurate Blueprint - by tllim - 02-01-2016, 11:16 PM
RE: Solid Model/Accurate Blueprint - by Dtaivpp - 03-30-2016, 11:16 AM
RE: Solid Model/Accurate Blueprint - by Tarjei85 - 03-30-2016, 03:30 PM
RE: Solid Model/Accurate Blueprint - by Tarjei85 - 03-31-2016, 02:13 AM
RE: Solid Model/Accurate Blueprint - by Tarjei85 - 04-13-2016, 09:45 AM
RE: Solid Model/Accurate Blueprint - by norm24 - 04-14-2016, 03:56 PM
RE: Solid Model/Accurate Blueprint - by knightridar - 06-11-2016, 03:35 AM
Question Complete blueprint of the Pine Tarjei85 11 31,264 06-11-2016, 09:06 AM
