Pinetab2 screen issue. screen does not power on at all
(09-18-2023, 04:58 PM)bluemage Wrote: So my pinetab2 doesn't seem to have a working screen in some capacity. I've gone through the https://wiki.pine64.org/wiki/PineTab2#In...structions I used disks to make a sd card that had the factory default danctnix on it and when I plugged it into uart and press power a little under 2 seconds I get using minicom
DDR Version 1.13 2022018
In
I'm not sure what I'm doing wrong or what this means. Initial googling of the above text doesn't seem to help. I'm not sure if I need to add a boot flag to any partitions. I may try something other than dancnix on the sd card and see if that gives the same or different results. I'm also using xubuntu and raspbian to run the minicom.
In
I just tried flashing ubports image and it gives slightly different text...
DDR Vl.16 6f7ic738ce typ  23/03/02-20:01:48
LP4/4x derate en, other dram:1x trefi
still no power for the screen.
after waiting a while mincom also outputed
unknown device
error
ERR
From error description, possible caused by LCD flex cable. Please reseat the LCD flex cable and hopefully issue resolved.
RE: Pinetab2 screen issue. screen does not power on at all - by tllim - 09-19-2023, 10:01 PM
  New PineTab2 dRateNWAytORy 2 553 05-11-2024, 09:46 AM
Last Post: frtodd
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 384 03-06-2024, 07:22 PM
Last Post: genobraker
  Bricked my PineTab2 using Jumpdrive? jkboyd 2 601 02-24-2024, 07:14 PM
Last Post: jkboyd
  Castle Game Engine on PineTab2 now officially available michalis 1 1,024 12-14-2023, 12:22 AM
Wink Screen protector for PineTab 2 vatin 0 702 11-18-2023, 01:31 AM
Last Post: vatin
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 894 11-05-2023, 10:20 AM
Last Post: WEF
  What's the MAX RAM you can install to PineTab2? Ptab2newb 2 1,188 09-12-2023, 12:38 PM
Last Post: Ptab2newb
  Booting from SD card on Pinetab2 samochimaaron 10 3,552 08-23-2023, 09:38 AM
Last Post: diederik
  PineTab 2 Dead Screen Kramey 16 5,510 08-12-2023, 05:44 PM
Last Post: Kramey
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,590 07-14-2023, 03:09 AM
Last Post: gregb49
