packages held back
(09-18-2023, 04:12 AM)user641 Wrote:
(09-18-2023, 02:14 AM)diederik Wrote: Please report this to the mobian devs (on their Matrix channel or https://salsa.debian.org/Mobian-team/met...n/-/issues (if you have a Salsa account)) as this is something they need to fix.
If you have 'aptitude' installed, you can run "aptitude full-upgrade -s" ('-s' = simulate) and it'll tell you why it can't do a safe-upgrade.
I did a sudo apt install mobian-base mobian-phone-base mobian-phosh-base mobian-phosh-phone
and it show me that  would remove some pulseaudio packages and install some pipewire...it's abou that debian transition...we can just wait.  I will report it on salsa, but I am sure they are aware of it.
In that case using full-upgrade is likely the right thing to do.
https://salsa.debian.org/Mobian-team/met...ngelog#L15 shows:
d/control: switch to pipewire for audio
If pulseaudio was marked as manually installed (thus NOT automatically installed), then you do need to do a full-upgrade.
I think that indicates that the packaging could've been better, but I'm still at the beginning of my learning track wrt those things.
BTW: Kudos for not blindly running full-upgrade Cool (too many ppl break their system by doing that)
packages held back - by user641 - 09-17-2023, 03:08 AM
RE: packages held back - by diederik - 09-18-2023, 02:14 AM
RE: packages held back - by user641 - 09-18-2023, 04:12 AM
RE: packages held back - by diederik - 09-18-2023, 05:53 AM
RE: packages held back - by user641 - 09-18-2023, 10:00 AM
RE: packages held back - by diederik - 09-18-2023, 11:05 AM
RE: packages held back - by user641 - 09-18-2023, 11:16 AM
RE: packages held back - by diederik - 09-18-2023, 03:05 PM
  When are we getting Geary back? LibrePhoneUser 15 12,432 12-09-2022, 04:18 AM
Last Post: Anna
  Wifi issue since last update and held back updates goku499 11 11,918 09-21-2022, 02:39 PM
Last Post: Katsujinken
  How to move Firefox address bar back to top? Zebulon Walton 5 5,711 06-11-2022, 09:41 AM
Last Post: iwakura_lain
  Epiphany browser broken after webkit packages upgrade user641 0 1,710 04-15-2022, 05:20 AM
Last Post: user641
  Packages being kept back user641 2 3,434 02-08-2022, 05:34 PM
Last Post: user641
  need my usb tethering back HLing 12 15,194 08-02-2021, 10:13 AM
  "Unable to download updates: The following packages have unmet dependencies:" bitnick 13 18,002 04-23-2021, 09:45 PM
Last Post: ryo
