SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating
(09-04-2023, 09:36 AM)bacon_dude Wrote: it was a problem with the connector to the screen.
I pushed it in and it started to work, but it stopped after a while. After more probing I found that I needed to keep pressure in one spot on the little board across the battery from the rest of the stuff (hidden under the strip of tape). My solution to keeping constant pressure there was to cut a small piece of eraser and tape it in place, that way the case will constantly push on it. Probably not the best solution, but seems to be working for now.
Once the screen was working i could flash it and it boots up.
May be due to LCD flex cable, you can file ticket at https://support.pine64.org explain your situation and request for LCD flex cable replacement.
RE: New PineTab2 not booting properly. - by tllim - 09-05-2023, 05:47 PM
  Pinetab2 not starting Corconegre 6 1,750 03-18-2024, 10:47 AM
Last Post: zogkarndon
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 484 03-16-2024, 11:56 AM
Last Post: scottgr
  pinetab2 hardware is not very good lmartin 11 2,554 01-13-2024, 03:45 AM
Last Post: Darth-Apple
Information nvme ssd and open pinetab2 snock 0 245 01-12-2024, 06:37 PM
Last Post: snock
  Pinetab2 screen removal Corconegre 5 1,464 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 683 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 371 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 551 10-14-2023, 05:48 PM
Last Post: lockedpotato
  pinetab2 booting when adapter connected Ome Ko 16 3,180 09-15-2023, 11:45 PM
Last Post: Ome Ko
  PineTab2 screen won't turn back on until reboot KelsonV 3 1,147 08-23-2023, 09:08 AM
Last Post: diederik
