SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating
it was a problem with the connector to the screen.
I pushed it in and it started to work, but it stopped after a while. After more probing I found that I needed to keep pressure in one spot on the little board across the battery from the rest of the stuff (hidden under the strip of tape). My solution to keeping constant pressure there was to cut a small piece of eraser and tape it in place, that way the case will constantly push on it. Probably not the best solution, but seems to be working for now.
Once the screen was working i could flash it and it boots up.
RE: New PineTab2 not booting properly. - by bacon_dude - 09-04-2023, 09:36 AM
RE: New PineTab2 not booting properly. - by tllim - 09-05-2023, 05:47 PM
  PineTab2 spec for ddr and rth 0 743 12-09-2025, 08:28 PM
Last Post: rth
  Pinetab2 not starting Corconegre 12 20,308 07-25-2025, 03:04 AM
  What is the state of the PineTab2 today? Arcikks 2 2,419 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 11,809 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 2,762 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 5,350 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 3,485 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 1,853 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 1,817 10-14-2023, 05:48 PM
Last Post: lockedpotato
  pinetab2 booting when adapter connected Ome Ko 16 11,843 09-15-2023, 11:45 PM
Last Post: Ome Ko
