Pinetab2 screen removal
so i have been able to successfully disassemble/reassemble my pt2 after my mainboard got fried in a storm.
separating the screen from the back plate can be a bit daunting, especially since there are moments when the screen could bend/break when prying.
to outline, as best i can, what i found to make removing the screen easiest is to have 2-4 of these kind of pry tools: https://ae01.alicdn.com/kf/Hb26e538d13df...ar-Pry.jpg i recommend having several b/c one side can chew one of these up pretty bad. since i only had 2, i used a knife to clean up the pry edges between each side.
what i did was start with the "top side" where the buttons and ports are. once i was able to get it into the space between the screen and bezel, i was able to move the pry tool from corner to corner and release the tabs. from there i moved in a rotation, going to the bottom edge of the display and separating that side, then the next short side, and finally the last long side.
be patient and take your time, but you can have it done within 10-15m.
Pinetab2 screen removal - by Corconegre - 08-29-2023, 05:16 AM
RE: Pinetab2 screen removal - by RTP - 08-29-2023, 10:33 PM
RE: Pinetab2 screen removal - by Corconegre - 08-31-2023, 03:07 PM
RE: Pinetab2 screen removal - by tophneal - 09-01-2023, 08:03 AM
RE: Pinetab2 screen removal - by monwarez - 01-08-2024, 05:40 PM
RE: Pinetab2 screen removal - by stozi - 01-10-2024, 08:08 AM
  Pinetab2 not starting Corconegre 12 18,939 07-25-2025, 03:04 AM
  cracked screen and repair elix 0 1,486 03-07-2025, 01:40 PM
Last Post: elix
  What is the state of the PineTab2 today? Arcikks 2 1,991 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 10,304 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 2,345 03-16-2024, 11:56 AM
Last Post: scottgr
  PineTab2, Ubuntu Touch and WiFI JMoore 2 2,947 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 1,580 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 1,567 10-14-2023, 05:48 PM
Last Post: lockedpotato
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 1,840 09-28-2023, 01:06 PM
Last Post: dynobang
  pinetab2 booting when adapter connected Ome Ko 16 10,551 09-15-2023, 11:45 PM
Last Post: Ome Ko
