pinetab2 booting when adapter connected
(08-27-2023, 12:10 PM)Ome Ko Wrote:
(08-27-2023, 11:32 AM)frtodd Wrote: The machine starts up when you plug it into a power source. That's a known "feature." I try to plug it in before shutting it down. Then it stays shutdown.
I'm wondering: is this a pine-feature or a linux feature?
So I'm really curious who figured this "feature" out. Was it this Thorvalds fellow, one of his nephews at Danctnix, somebody at the pineclub or one of the factory workers where our tablets are being assembled?
It isn't a feature, it's a bug. The PineTab2 works surprisingly well given how new it is and thus how much work has been done on the software side.
And that includes the kernel/DeviceTree side of things.
Audio (together) with headphones didn't work correctly at first, but if you got the latest update(s), then it should all work properly.
I know this charging/poweron issue is known, but I do not yet know if there is a solution and/or whether it's deployed yet.
And there are other known and unknown issues which hopefully all get resolved at some point.
And if you try to be snarky/funny, at least get Torvalds name right ...
RE: pinetab2 booting when adapter connected - by diederik - 08-28-2023, 02:15 PM
  PineTab2 spec for ddr and rth 0 876 12-09-2025, 08:28 PM
Last Post: rth
  Pinetab2 not starting Corconegre 12 20,448 07-25-2025, 03:04 AM
  What is the state of the PineTab2 today? Arcikks 2 2,461 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 11,910 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 2,797 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 5,384 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 3,544 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 1,871 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 1,827 10-14-2023, 05:48 PM
Last Post: lockedpotato
  SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating bacon_dude 6 7,296 09-06-2023, 07:43 PM
Last Post: bacon_dude
