pinetab2 booting when adapter connected
Lightbulb
(08-28-2023, 05:44 AM)dachalife Wrote: Why don’t you just connect the PT2 to a powerbank, turn it off and your dynamo to the powerbank?
Good thinking!
Unfortunately charging a battery by a battery doubles the efficiency losses. Due to heat dissipation as a result of transition resistance, the losses while charging a battery amount to 20% depending on hardware and current.
Your proposal would reduce the overall charging efficiency to 60% which is a really demotivating number when you have to pedal the power into your pinetab yourself...
Quote:It sounds like, as dachalife suggested, you may want a little bit more self-crafted hardware to maintain that 5v at traffic lights and such. But this "feature" is going to be a pain for you, for sure.
You are right. It would involve a bufferdevice; i.e. an extra battery with the aforementioned setbacks...
RE: pinetab2 booting when adapter connected - by Ome Ko - 08-28-2023, 09:30 AM
  PineTab2 spec for ddr and rth 0 883 12-09-2025, 08:28 PM
Last Post: rth
  Pinetab2 not starting Corconegre 12 20,454 07-25-2025, 03:04 AM
  What is the state of the PineTab2 today? Arcikks 2 2,464 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 11,916 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 2,797 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 5,388 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 3,550 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 1,872 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 1,827 10-14-2023, 05:48 PM
Last Post: lockedpotato
  SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating bacon_dude 6 7,306 09-06-2023, 07:43 PM
Last Post: bacon_dude
