Pinephone won't boot.
(08-18-2023, 12:56 AM)spha Wrote:
(08-17-2023, 02:31 PM)fxc Wrote:
(08-17-2023, 11:49 AM)spha Wrote: Pinephone screen stopped working. The system starts but the screen is black. When starting the jumpdrive, the screen is bright gray, but after an hour of charging, nothing has changed. The battery voltage is 3.76 volts. I have tried different operating systems and chargers. The last time it worked, I turned it off by holding the power button and put it on the table.
Which Jumpdrive image did you flash? Jumpdrive is not supposed to show a gray screen, instead it should show this screen: https://wiki.pine64.org/images/1/1a/Jumpdrive.jpg
The rest of the symptoms describe a drained battery, maybe beyond the point of saving. Mind that in this state, charging it for only one hour in Jumpdrive is not sufficient, at this state it will charge very slowly and it is required to charge it multiple hours until the drained battery takes some charge again.
I used both jumpdrive images. pine64-pinephone-charging.img.xz and pine64-pinephone.img.xz.
/home/spha/Загрузки/pine64-pinephone.img.xz
Please don't use the charging image, it disables the screen and it would match what you described (no screen output, possibly only backlight). I would suggest that you redownload https://github.com/dreemurrs-embedded/Ju...one.img.xz and check if you get a screen output with that.
(08-17-2023, 04:47 PM)Kevin Kofler Wrote:
(08-17-2023, 02:31 PM)fxc Wrote: The rest of the symptoms describe a drained battery
Do they really? The user reports a battery voltage of 3.76V. According to the battery data sheet, the "nominal voltage" is 3.8V, the "end of discharge voltage" is 3.0±0.05V. Considering those numbers, 3.76V does not sound like a badly discharged battery to me.
4.20 V when it is full. After an hour of charging it should be more than that, 3.76 V is in the bottom 0-10 %. I don't trust these measurements and am not considering them in my reply.
Pinephone won't boot. - by spha - 08-17-2023, 11:49 AM
RE: Pinephone won't boot. - by fxc - 08-17-2023, 02:31 PM
RE: Pinephone won't boot. - by Kevin Kofler - 08-17-2023, 04:47 PM
RE: Pinephone won't boot. - by spha - 08-18-2023, 12:56 AM
RE: Pinephone won't boot. - by fxc - 08-18-2023, 01:28 AM
RE: Pinephone won't boot. - by spha - 08-18-2023, 01:38 AM
RE: Pinephone won't boot. - by fxc - 08-18-2023, 02:33 AM
RE: Pinephone won't boot. - by spha - 08-18-2023, 02:45 AM
RE: Pinephone won't boot. - by spha - 08-18-2023, 05:09 AM
RE: Pinephone won't boot. - by fxc - 08-19-2023, 05:19 AM
RE: Pinephone won't boot. - by spha - 08-20-2023, 02:44 AM
RE: Pinephone won't boot. - by mikehenson - 08-18-2023, 08:15 AM
RE: Pinephone won't boot. - by spha - 08-18-2023, 08:48 AM
RE: Pinephone won't boot. - by Richy_T - 05-15-2024, 10:31 PM
  How can I record video on a Pinephone? kk22 23 19,121 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 5,921 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 6,311 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 631 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 3,684 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,137 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 911 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 5,683 10-21-2025, 12:12 PM
Last Post: Richy_T
  Does PinePhone support long-term battery health optimization? roseblack 5 2,260 10-06-2025, 09:05 PM
  iso pinephone for sale (USA) elwoodb25 0 4,246 09-24-2025, 09:25 PM
Last Post: elwoodb25
