Pinetab2 not starting
(08-17-2023, 07:13 AM)Corconegre Wrote: Hi all,
after a month using my pinetab2 the screen started flickering one day then i got a screen with colored vertical thin lines (image attached), and now it does not start at all.
I did not do any software upgrade during the weeks previous to this happening and i'm running the installation that came with the device.
I tried to plug the UART to the lower usb-c and followed the instructions here:
https://wiki.pine64.org/wiki/PineTab2#Co...RT_adapter
To see if i could see something but it looks like the device does not even start, i also tried to reset it (using the press 7 seconds, 3 second wait, 3-4 seconds press) several times but nothing happens, also left it charging overnight without any result.
From the outside i do not see any light or anything else, just the green light on the UART when it's plugged via USB to the computer.
Anyone can give me advice on what to do next? i'm a bit lost now.
Thanks!
Try to reseat the LCD ribbon cable and check whether help.
Pinetab2 not starting - by Corconegre - 08-17-2023, 07:13 AM
RE: Pinetab2 not starting - by tllim - 08-23-2023, 02:57 PM
RE: Pinetab2 not starting - by Corconegre - 08-24-2023, 10:10 AM
RE: Pinetab2 not starting - by tllim - 08-26-2023, 06:20 PM
RE: Pinetab2 not starting - by Corconegre - 08-31-2023, 03:08 PM
RE: Pinetab2 not starting - by zkajdan - 12-25-2023, 02:24 PM
RE: Pinetab2 not starting - by zogkarndon - 03-18-2024, 10:47 AM
RE: Pinetab2 not starting - by angeloweb - 06-02-2024, 04:11 PM
RE: Pinetab2 not starting - by tllim - 06-03-2024, 01:43 PM
RE: Pinetab2 not starting - by angeloweb - 06-17-2024, 06:40 PM
RE: Pinetab2 not starting - by snowka - 03-06-2025, 04:08 PM
RE: Pinetab2 not starting - by lchauvin - 07-23-2025, 12:39 PM
RE: Pinetab2 not starting - by biketool - 07-25-2025, 03:04 AM
  What is the state of the PineTab2 today? Arcikks 2 1,996 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 10,340 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 2,350 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 4,726 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 2,952 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 1,581 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 1,567 10-14-2023, 05:48 PM
Last Post: lockedpotato
  pinetab2 booting when adapter connected Ome Ko 16 10,596 09-15-2023, 11:45 PM
Last Post: Ome Ko
  SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating bacon_dude 6 6,142 09-06-2023, 07:43 PM
Last Post: bacon_dude
  PineTab2 screen won't turn back on until reboot KelsonV 3 3,706 08-23-2023, 09:08 AM
Last Post: diederik
