Internal WiFi status?
#19
Wifi and bluetooth are now available for testing in the default Arch distro as of kernel 6.6.13-danctnix1-1-pinetab2. Here's how to enable them (if you're running an alternate distro, please check your distro's documentation instead):
First, check to see if you are running the latest version via
uname -a
. If not, update with
sudo pacman -Syu
and reboot. You will need to use a wifi dongle or tether a phone to do this initial update: see the documentation page for details.
Wifi
Enable wifi for a single session with
sudo modprobe bes2600
. This will persist until you reboot your device.
To enable wifi at each boot:
sudo -i
echo bes2600 | sudo tee /etc/modules-load.d/bes2600.conf
exit
Note: Wifi is still being tested and as of this post causes issues with suspend and may cause the device to hang on shutdown.
Bluetooth
Enter these commands in order:
sudo pacman -S bluez-deprecated-tools
sudo -i
echo ifname:bt cmd:BT_ON > /dev/bes2600
rfkill unblock bluetooth
hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep
hciconfig hci0 up
exit
sudo systemctl enable bluetooth
Internal WiFi status? - by acruhl - 08-04-2023, 09:26 PM
RE: Internal WiFi status? - by rqkeating - 08-05-2023, 07:32 AM
Internal WiFi status? - by moobythegoldensock - 08-05-2023, 11:40 AM
RE: Internal WiFi status? - by lockedpotato - 09-24-2023, 04:29 PM
RE: Internal WiFi status? - by explit - 11-30-2023, 04:41 AM
RE: Internal WiFi status? - by Corfromleuven - 12-07-2023, 04:42 AM
RE: Internal WiFi status? - by explit - 12-07-2023, 05:10 AM
RE: Internal WiFi status? - by diederik - 12-07-2023, 09:55 AM
RE: Internal WiFi status? - by fretinator - 12-15-2023, 06:18 PM
RE: Internal WiFi status? - by u974615 - 12-20-2023, 11:10 AM
RE: Internal WiFi status? - by diederik - 12-20-2023, 12:50 PM
RE: Internal WiFi status? - by stevepaesani - 06-06-2025, 08:13 PM
RE: Internal WiFi status? - by polrus - 01-09-2024, 05:28 AM
RE: Internal WiFi status? - by explit - 01-09-2024, 06:44 AM
RE: Internal WiFi status? - by tophneal - 01-09-2024, 02:38 PM
RE: Internal WiFi status? - by explit - 01-09-2024, 08:57 PM
Internal WiFi status? - by moobythegoldensock - 01-10-2024, 02:07 PM
RE: Internal WiFi status? - by explit - 01-10-2024, 06:38 PM
RE: Internal WiFi status? - by Kevin Kofler - 01-10-2024, 07:56 PM
Internal WiFi status? - by moobythegoldensock - 02-06-2024, 05:14 PM
RE: Internal WiFi status? - by Surehand53 - 02-14-2024, 08:05 AM
RE: Internal WiFi status? - by Corkonian - 02-13-2024, 08:41 AM
RE: Internal WiFi status? - by Wilmeri - 02-16-2024, 05:08 AM
RE: Internal WiFi status? - by ninlith - 02-23-2024, 01:59 PM
RE: Internal WiFi status? - by ninlith - 02-23-2024, 04:48 PM
RE: Internal WiFi status? - by frtodd - 02-23-2024, 08:43 PM
RE: Internal WiFi status? - by FortunateFowl - 02-24-2024, 12:57 PM
RE: Internal WiFi status? - by Wilmeri - 03-01-2024, 01:42 PM
RE: Internal WiFi status? - by Username_012 - 02-24-2024, 10:08 PM
RE: Internal WiFi status? - by Kevin Kofler - 02-25-2024, 02:22 AM
RE: Internal WiFi status? - by Username_012 - 02-26-2024, 07:31 AM
RE: Internal WiFi status? - by Kevin Kofler - 02-26-2024, 07:51 AM
RE: Internal WiFi status? - by Username_012 - 02-26-2024, 08:53 PM
RE: Internal WiFi status? - by mtomaschett - 03-09-2024, 05:22 PM
RE: Internal WiFi status? - by pinewood - 04-30-2024, 12:07 PM
RE: Internal WiFi status? - by cringeops - 05-04-2024, 08:00 AM
RE: Internal WiFi status? - by wolfallein - 06-15-2025, 04:52 AM
RE: Internal WiFi status? - by Kevin Kofler - 06-07-2025, 03:50 AM
  Wifi with iwd and/or connman ? louson 4 1,612 04-07-2025, 01:16 PM
Last Post: louson
  PineTab (early adopters) wifi broken in kernel 6.12 bartgrefte 0 1,129 03-23-2025, 05:25 AM
Last Post: bartgrefte
  Wifi works! WEF 0 1,593 08-02-2024, 11:14 AM
Last Post: WEF
  Video Tutorial: SDR/GQRX- Listening In To Voice On Pinetab (Internal SDR) RTP 1 3,940 03-08-2021, 09:33 AM
Last Post: barray
