Does latest Tow-Boot install/work correctly for everyone?
(08-03-2023, 02:54 PM)tophneal Wrote:
(08-03-2023, 02:27 PM)dukla2000 Wrote:
(08-03-2023, 12:31 PM)tophneal Wrote: ...
So I'm curious now if anyone else has had this or a similar issue when trying to install tow-boot through SD installer or writing directly to mtd0 from within a booted OS. I'd raise it as an issue on the Github, but I want to be sure I haven't overlooked any potential solutions and I know @samueldr has indicated he isn't able to be as active in maintaining/troubleshooting as before.
Not what you asked, but pine64-pinephonePro-2022.07-006 worked fine for me on my PPP. 35Mb spi.installer.img was dd'd to a tatty old SD on my RPro64 then that booted fine on my PPP and I could do the install.
Same RK3399 ...
FWIW my SDcard looks like (on the RPro64)
$ lsblk
mmcblk1      179:96   0   3.7G  0 disk
├─mmcblk1p1  179:97   0    12M  0 part
└─mmcblk1p2  179:98   0    22M  0 part /run/media/chris/57f8f4bc-abf4-655f-bf67-946fc0f9f25b
Are you sure you have the correct bits held/flicked/switched to get your PBP booting from the SDcard?
On the basis there isn't that much difference between the boards would be tempted to at least try the PPP and/or RPro64 Tow-Boots - at least you should get to the Tow-Boot menu, whether you actually flash is another call. But would eliminate that the PBP download is a duffer.
I made sure I wouldn't need to open it up (and force myself to follow through on my decision) by wiping the eMMC already. There's nothing on the eMMC anymore and the PBP only boots when I insert a ready-to-boot SD, like my early Fedora install, into it. In fact, I recall when I first tested the SD installer of 2021.10-03 I had 0 issue with the SD booting before the BSP on the eMMC.
Mine shows as /dev/sda since I'm working off of an SD boot, but it matches yours (aside from the sda2 mount location.) Since posting, I've also tried writing the image to a different, larger SD card, and writing the installer from a different computer. No success with either. Sad
My best guess so far is a bad video driver, based off of some posts concerning an earlier iteration of tow-boot, though a part of me just can't believe that's the case. The issue was years ago, this should be a 2020 batch member, and there's soooooo many successful installs out there. I suppose I should find/dig out the serial cable for this and see if I can get anything from that.
You guess may be right, I have voiced out on last year that tow-boot may be using older video driver and seems like no update :-( This is one of the main reason that product team decided not to preinstalled tow-boot on current Pinebook Pro production batch.
RE: Does latest Tow-Boot install/work correctly for everyone? - by tllim - 08-03-2023, 03:21 PM
  Cant boot into an OS trashtendenz 4 1,572 06-26-2025, 02:20 AM
Last Post: samlevy0515
  3 days in, slow/stuck or no boot. lgmpbp2 34 11,409 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 6,796 04-03-2025, 07:47 AM
Last Post: Tazdevl
  Use SD to install new OS over pinebook debian Rudy558 10 15,004 03-09-2025, 11:17 AM
Last Post: davisthomas
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 4,938 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 778 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Unable to boot? YossiS 4 1,432 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 4,100 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 1,049 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 5,511 12-15-2023, 02:11 PM
