bes2600 driver
(08-18-2023, 06:17 AM)FortunateFowl Wrote: I feel like the original request of getting step by step instructions on building the driver is quite reasonable. I am not sure why there wasn't a straightforward answer given.
Yes the replies above are correct, it appears it isn't ready for deployment, and you probably shouldn't try to build it in order to get wifi on your tablet. However, that is no reason to not answer how to build it to see for yourself.
First step, you'll need the tools to make and compile, as well as the kernel headers to compile against.
$ sudo pacman -S make gcc linux-pinetab2-headers
Then git cloning to get the current module code.
$ git clone 'https://gitlab.com/TuxThePenguin0/bes2600'
Then try to make the module, I am not sure it will even compile at this point however.
thanks.
I tried on mobian. After git clone I did make then insmod bes2600.ko . I received error:
insmod: ERROR: could not insert module bes2600.ko: Unknown symbol in module
bes2600 driver - by mshelby - 07-16-2023, 09:59 PM
RE: bes2600 driver - by gregb49 - 07-17-2023, 11:46 AM
RE: bes2600 driver - by diederik - 07-17-2023, 05:02 PM
RE: bes2600 driver - by dachalife - 07-18-2023, 09:32 AM
RE: bes2600 driver - by zoward - 07-21-2023, 02:21 PM
RE: bes2600 driver - by frtodd - 07-23-2023, 02:33 PM
RE: bes2600 driver - by mshelby - 08-09-2023, 09:06 AM
RE: bes2600 driver - by FortunateFowl - 08-18-2023, 06:17 AM
RE: bes2600 driver - by spenk - 08-23-2023, 06:49 AM
RE: bes2600 driver - by arjan1995 - 09-01-2023, 07:21 AM
RE: bes2600 driver - by tllim - 09-03-2023, 11:20 PM
RE: bes2600 driver - by gregb49 - 09-15-2023, 07:28 AM
RE: bes2600 driver - by mshelby - 10-19-2023, 09:40 AM
RE: bes2600 driver - by dekker - 11-03-2023, 11:18 AM
RE: bes2600 driver - by zoward - 09-04-2023, 04:59 PM
RE: bes2600 driver - by m3henry - 09-10-2023, 06:07 PM
RE: bes2600 driver - by 459below - 10-06-2023, 02:53 PM
RE: bes2600 driver - by spenk - 10-20-2023, 01:49 PM
RE: bes2600 driver - by 459below - 11-05-2023, 08:38 PM
RE: bes2600 driver - by genobraker - 11-22-2023, 01:48 PM
RE: bes2600 driver - by 459below - 11-28-2023, 03:28 PM
RE: bes2600 driver - by genobraker - 11-29-2023, 07:11 PM
RE: bes2600 driver - by explit - 11-19-2023, 06:09 PM
RE: bes2600 driver - by Kevin Kofler - 11-19-2023, 11:59 PM
RE: bes2600 driver - by explit - 11-20-2023, 06:20 AM
RE: bes2600 driver - by Kevin Kofler - 11-20-2023, 04:36 PM
RE: bes2600 driver - by explit - 11-20-2023, 05:19 PM
RE: bes2600 driver - by Kevin Kofler - 11-21-2023, 06:42 PM
RE: bes2600 driver - by explit - 11-21-2023, 10:27 PM
RE: bes2600 driver - by Kevin Kofler - 11-21-2023, 10:44 PM
RE: bes2600 driver - by explit - 11-22-2023, 11:24 AM
RE: bes2600 driver - by explit - 11-22-2023, 05:15 PM
RE: bes2600 driver - by Kevin Kofler - 11-23-2023, 11:21 PM
RE: bes2600 driver - by explit - 11-24-2023, 12:37 AM
RE: bes2600 driver - by explit - 11-26-2023, 06:19 PM
RE: bes2600 driver - by Kevin Kofler - 11-24-2023, 05:53 AM
RE: bes2600 driver - by Kevin Kofler - 11-26-2023, 10:27 PM
RE: bes2600 driver - by explit - 11-28-2023, 09:38 AM
RE: bes2600 driver - by diederik - 11-29-2023, 07:26 PM
RE: bes2600 driver - by explit - 11-28-2023, 08:19 PM
RE: bes2600 driver - by explit - 11-29-2023, 02:01 AM
RE: bes2600 driver - by explit - 11-29-2023, 07:19 PM
RE: bes2600 driver - by tophneal - 11-30-2023, 08:50 AM
RE: bes2600 driver - by gregb49 - 11-30-2023, 09:10 AM
RE: bes2600 driver - by tllim - 12-09-2023, 01:39 AM
RE: bes2600 driver - by mattpenn - 12-01-2023, 12:48 PM
RE: bes2600 driver - by 459below - 12-03-2023, 09:14 AM
RE: bes2600 driver - by explit - 12-03-2023, 10:36 AM
RE: bes2600 driver - by Kevin Kofler - 12-09-2023, 01:02 PM
RE: bes2600 driver - by tllim - 12-10-2023, 04:42 PM
RE: bes2600 driver - by diederik - 03-28-2024, 08:13 AM
RE: bes2600 driver - by u974615 - 12-19-2023, 03:30 PM
RE: bes2600 driver - by 459below - 12-24-2023, 03:43 AM
RE: bes2600 driver - by explit - 03-15-2024, 06:09 PM
RE: bes2600 driver - by diederik - 03-29-2024, 08:33 AM
RE: bes2600 driver - by tllim - 05-12-2024, 11:09 PM
