Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159
(07-11-2023, 12:06 PM)hunderteins Wrote:
(07-11-2023, 01:12 AM)Thisone Wrote:
  CC [M]  /home/rock64/CH341SER_LINUX/driver/ch341.o
gcc: error: unrecognized command line option '-mgeneral-regs-only'
gcc: error: unrecognized command line option '-mcmodel=large'
scripts/Makefile.build:283: recipe for target '/home/rock64/CH341SER_LINUX/driver/ch341.o' failed
What version of gcc you are using? Your gcc doesn't understand the two commandline options '-mgeneral-regs-only' and '-mcmodel=large'
I'm on 6.0.0-1164-ayufan and compiling with gcc 13.1.1 that driver works like a charm:
$ make
make -C /lib/modules/6.0.0-1164-ayufan-ga2fd0c498/build  M=/tmp/CH341SER_LINUX/driver
make[1]: Entering directory '/usr/src/linux-headers-6.0.0-1164-ayufan-ga2fd0c498'
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: aarch64-linux-gnu-gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0
  You are using:           aarch64-alt-linux-gcc (GCC) 13.1.1 20230613 (ALT Sisyphus 13.1.1-alt1)
  CC [M]  /tmp/CH341SER_LINUX/driver/ch341.o
  MODPOST /tmp/CH341SER_LINUX/driver/Module.symvers
  CC [M]  /tmp/CH341SER_LINUX/driver/ch341.mod.o
  LD [M]  /tmp/CH341SER_LINUX/driver/ch341.ko
make[1]: Leaving directory '/usr/src/linux-headers-6.0.0-1164-ayufan-ga2fd0c498'
That driver loads into that kernel without complaint:
[  152.041600] ch341: loading out-of-tree module taints kernel.
[  152.042335] usbcore: registered new interface driver usb_ch341
[  152.042341] ch341: USB serial driver for ch340, ch341, etc.
[  152.042344] ch341: V1.6 On 2022.08
May be is is incompatible with the legacy kernel?
I still get the same error after updating gcc to gcc-9 following this tutorial: How to Install GCC Compiler on Ubuntu 18.04 | Linuxize
RE: Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 - by Thisone - 07-12-2023, 01:14 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 693 03-25-2024, 12:12 PM
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,745 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 933 09-22-2023, 04:27 AM
Last Post: diederik
  GPIO on Ayufan 0.9.14 Build Thisone 7 2,306 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,102 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 1,407 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  RockPro64 linux console video mode callegar 0 921 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,459 04-30-2022, 03:57 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,454 01-03-2022, 10:32 AM
Last Post: whitecat23
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 1,490 07-24-2021, 09:46 PM
Last Post: Mentaluproar
