Haven't seen updates in a while
(06-24-2023, 01:39 PM)mdk Wrote: That's what we call Debian stable, you know,it's stable Smile))
See https://blog.mobian.org/posts/2023/06/10/bookworm/
RIght! Smile However this is the first time I've seen no updates for any length of time. Probably because Debian 12 is now officially released, hadn't thought of that.
(06-24-2023, 01:41 PM)zetabeta Wrote: basically you need to choose between bookworm and trixie, https://blog.mobian.org/posts/2023/06/10/bookworm/ .
if staying with bookworm, then bookworm-security is needed.
Thanks, I'll probably stay with "stable" unless I hear one of the issues I'm still seeing (like no volume control on calls and bluetooth audio not working) is supposed to be fixed. (I did try pipewire - volume controls worked but audio routing was totally screwed up, so I went back to pulseaudio.)
I'll update my apt sources to include bookworm-security.
RE: Haven't seen updates in a while - by mdk - 06-24-2023, 01:39 PM
RE: Haven't seen updates in a while - by zetabeta - 06-24-2023, 01:41 PM
RE: Haven't seen updates in a while - by Zebulon Walton - 06-24-2023, 04:29 PM
  No volume control after latest updates Zebulon Walton 19 17,980 09-08-2023, 08:28 AM
Last Post: jessencan
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 14,743 08-31-2023, 12:38 PM
Last Post: vusra
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 21,644 10-14-2022, 05:38 PM
Last Post: Krafter
  Wifi issue since last update and held back updates goku499 11 13,359 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Glacially slow system updates on Mobian - waiting on boot 20m - 1h bujiraso 5 7,122 03-01-2022, 10:06 AM
Last Post: bujiraso
  No updates after upgrade? jojuma 3 4,863 08-26-2021, 08:53 PM
Last Post: bcnaz
  "Unable to download updates: The following packages have unmet dependencies:" bitnick 13 19,797 04-23-2021, 09:45 PM
Last Post: ryo
  Issues with Mobian 20210314 (data and updates) IMSAI8080 5 9,774 03-20-2021, 04:14 AM
Last Post: IMSAI8080
  Stable build and updates ergo owl 3 6,786 09-19-2020, 06:59 AM
Last Post: User 18618
Question Question re updates and nightly images JustineSmithies 1 4,246 06-27-2020, 12:24 PM
Last Post: devrtz
