how to disable ipv6 at kernel level with towboot?
(06-19-2023, 03:13 PM)vusra Wrote: Adding  U_BOOT_PARAMETERS="ipv6.disable=1"   to /etc/default/u-boot        and run  u-boot-update use to work before tow boot.   What is the new methodology to pass  ipv6.disable=1 to kernel ?
i cannot be certain about kernel parameters with bootloader, but syntax should be same, just inserting the string input is little different, probably different place.
however, you could try sysctl.conf, this happens during boot of course, so it's not immediate.
# location: /etc/sysctl.conf
net.ipv6.conf.all.disable_ipv6=1
net.ipv6.conf.default.disable_ipv6=1
RE: how to disable ipv6 at kernel level with towboot? - by zetabeta - 06-19-2023, 06:06 PM
Big Grin An early xmas present: 6.1 kernel treebeard 28 22,859 07-18-2023, 03:14 AM
Last Post: gischpelino
  Stability problems with 6.1 kernel Zebulon Walton 9 6,987 05-12-2023, 08:09 AM
Last Post: zetabeta
  How to enable ipv6 for hotspot robgadget 1 2,140 04-28-2023, 06:59 AM
Last Post: wibble
  Disable headphone controls 3x5co 0 1,549 09-10-2022, 07:11 AM
Last Post: 3x5co
  Disable vibrations 3x5co 8 11,944 06-11-2022, 09:59 AM
Last Post: iwakura_lain
  Disable *automatic* on-screen keyboard iwakura_lain 0 1,829 06-11-2022, 09:49 AM
  Disable on screen keyboard permanently. grump_fiddle_reinstall 12 16,737 06-11-2022, 08:11 AM
Last Post: SwordfishII
  Hotspot and IPv6 gosh000 1 2,157 06-08-2022, 02:12 AM
Last Post: wibble
  Kernel 5.15 Zebulon Walton 10 11,121 11-27-2021, 01:10 PM
Last Post: LibrePhoneUser
  Mobian kernel upgrade user641 4 6,474 11-10-2021, 01:22 PM
Last Post: user641
