locked out on PIN screen
The software PIN (the *nix user password) or the SIM card PIN? And why are you locked out, did you forget the PIN, or enter a wrong one too often?
For the software PIN, the lock out if you enter it incorrectly too often normally only lasts 5 minutes or so, depending on your distro's PAM configuration. So you can just wait it out. And if you do not want to have it happen again, configure your pam_faillock: https://man.archlinux.org/man/core/pam/f....conf.5.en. And the software PIN can always be recovered by reinstalling the operating system. If you got your PinePhone Pro recently (since July 2022), it came with Tow-Boot already installed, so just hold the volume up button on startup to put it into USB mass storage mode, then you can backup the data (if you did not encrypt it with a passphrase that you do not remember) and reinstall an operating system image from a computer.
The SIM card PIN is a different story, if you entered the wrong one too often, you have to unlock the SIM card with the PUK.
locked out on PIN screen - by g40 - 06-07-2023, 05:15 AM
RE: locked out on PIN screen - by Kevin Kofler - 06-07-2023, 10:20 PM
  PinePhone Boots but only Shows Black Screen with Backlight danyeaw 1 2,355 06-30-2024, 10:18 AM
Last Post: danyeaw
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 11,765 08-28-2023, 11:38 AM
Last Post: fxc
Sad New PinePhone won't boot 9/10 times - Screen is on but stays black :( dante404 8 10,758 02-03-2023, 01:27 AM
Last Post: dante404
  My screen bottom side has loosed its tactile function arbocenc 1 2,332 01-06-2023, 10:02 AM
Last Post: britelite
  "PinenotePhone": Swap E-Ink Screen Onto Pinephone? britelite 0 1,822 01-03-2023, 06:17 PM
  Screen seems ok but no display UncleMeat 3 4,994 11-03-2022, 07:02 AM
Last Post: fxc
Question Black screen no matter the OS joseph303 2 3,625 07-19-2022, 01:07 AM
Last Post: joseph303
  Boot problem: wrong screen orientation Jetpac 6 7,642 07-18-2022, 12:47 PM
Last Post: fravoi
  Manjaro phosh no screen rotation sandspur 1 3,263 06-23-2022, 01:02 AM
Last Post: rapp
  Screen Lock Dinosaur1946 0 1,720 05-03-2022, 05:03 PM
Last Post: Dinosaur1946
