Sound : notifications
(06-06-2023, 06:34 AM)freelectro Wrote: Hi all,
To keep 4G active to receive notification from nheko and dino software, i use the following script.
https://gitea.privatedns.org/Xavi92/pinephone-scripts
Now, i receive notifications but i have no sound when receive.
I don't think it's due too this script.
How can i resolved this sound problem ?
Thanks a lot
When you are on lock screen notifications arrive as missed.
How notification are handled is configured here:
/usr/local/share/feedbackd/themes/
There are several config files and maybe you find correct one inside pine64,pinephone.json or default.json
Somewhere inside those files are examples for notifications who does make a sound - like message-new-sms
For example you can replace config of "message-new-sms" to "message-missed-instant" or "message-missed-email" and then you will get notification sound.
These two are the ones you want to find
And they are most likely under "silent" or "quiet" profile.
Sound : notifications - by freelectro - 06-06-2023, 06:34 AM
RE: Sound : notifications - by alaraajavamma - 06-06-2023, 06:58 AM
RE: Sound : notifications - by freelectro - 06-06-2023, 07:33 AM
RE: Sound : notifications - by alaraajavamma - 06-06-2023, 11:17 AM
RE: Sound : notifications - by freelectro - 06-06-2023, 02:05 PM
RE: Sound : notifications - by alaraajavamma - 06-06-2023, 02:18 PM
RE: Sound : notifications - by freelectro - 06-07-2023, 01:03 AM
  Does tow-boot allow periodic wake from suspension to check for notifications? DrPlamsa 4 5,385 12-31-2022, 10:56 AM
Last Post: DrPlamsa
Exclamation No sound anonymous 22 19,218 11-08-2022, 09:07 AM
Last Post: dante404
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 5,052 02-18-2022, 08:54 AM
Last Post: battlegarden
  Lost all sound Dinosaur1946 0 2,028 01-27-2022, 07:34 PM
Last Post: Dinosaur1946
  Sound design for Mobian S.E.B 4 5,474 12-27-2021, 05:40 AM
Last Post: Anna
  Customized Notifications - Non-native Apps arno_nuehm 2 3,780 10-05-2021, 09:42 AM
Last Post: kqlnut
  No notifications on lock screen DrPlamsa 16 16,511 08-21-2021, 05:35 AM
Last Post: bcnaz
  A clear all button for notifications is coming! ragreenburg 0 2,116 08-13-2021, 09:09 AM
Last Post: ragreenburg
  Software/Notifications battlegarden 4 6,533 05-01-2021, 03:22 PM
Last Post: MtnSk8
  Phone Shell and Dismissing Notifications on Mobian publiclewdness 0 2,171 04-10-2021, 01:41 PM
Last Post: publiclewdness
