Jabber with chatty
(11-10-2023, 01:23 AM)thomaschilton Wrote: Hello, I think you should check OMEMO compatibility: Ensure that the contacts you're trying to communicate with also have OMEMO encryption enabled and compatible clients. OMEMO requires both parties to have OMEMO-capable clients and compatible configurations for encryption to work properly.
Hey I checked that, that's not the problem, it works fine with dino for example, but chatty has this bug seems I will have to wait.
Jabber with chatty - by user641 - 05-03-2023, 07:54 AM
RE: Jabber with chatty - by thomaschilton - 11-10-2023, 01:23 AM
RE: Jabber with chatty - by user641 - 11-12-2023, 02:10 AM
  Chatty Matrix Decryption Key jojuma 2 2,441 02-26-2024, 12:48 PM
  Chatty does not work after suspend mode user641 4 5,014 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  beware chatty 0.7.0~rc0-1 treebeard 6 5,937 11-06-2022, 04:51 PM
Last Post: treebeard
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 8,769 09-30-2022, 08:53 PM
  Unable to send messages with chatty user641 0 1,685 09-07-2022, 04:35 AM
Last Post: user641
  Chatty - XMPP receiving photos - inline display doesn't work arkadione 2 3,810 07-10-2022, 03:16 AM
Last Post: arkadione
Sad Chatty can no longer start since the last update anonymous 10 10,138 06-08-2022, 01:03 PM
Last Post: Korac
  chatty v0.6 in Bookworm at last! treebeard 13 13,745 02-13-2022, 05:21 PM
  Chatty, SMS does not work - could hardware be at fault? AntonReiser 36 45,400 11-02-2021, 03:42 AM
Last Post: AntonReiser
  How Do I Perform a Chatty Application Reinstall? rrholmes 2 3,849 07-13-2021, 01:11 AM
Last Post: rrholmes
