I2C Expansion Board
#20
I had a look at the devicetree-file we use for the Linux kernel. Seems the I2C Interface for pin PL8/9 is not mapped. I then checked the usermanual and found out that this particular interface is actually different from TWI0/TWI1/TWI2.... it is named R_TWI and while it is the same hardware block, it does not sit on the APB2 bus like the others, it sits in the secure domain of the SoC on the APBS bus... so you can't just copy the dts entry from the others, fix the addresses/clocks/pins and call it a day... I am not sure what implications this has for adding it to the devicetree-file but I looked at R_UART - which is already configured (the name in the dts is s_uart though....) and found out that the secure devices have their own pin-control section, so that seems to be doable. What I do not know, what clock needs to be assigned to drive devices on the APBS bus? Also what are the correct IRQ definitions, I looked at the GIC IRQ table from the usermanual but couldnt figure out how the IRQ line numbers and vectors translate to the interrupt entries in the dts...
I2C Expansion Board - by DonFL - 07-21-2016, 11:15 AM
RE: I2C Expansion Board - by Artyom - 07-21-2016, 12:59 PM
RE: I2C Expansion Board - by DonFL - 07-21-2016, 01:17 PM
RE: I2C Expansion Board - by khgoh - 07-21-2016, 07:16 PM
RE: I2C Expansion Board - by MarkHaysHarris777 - 07-21-2016, 10:34 PM
RE: I2C Expansion Board - by DonFL - 07-22-2016, 12:28 AM
RE: I2C Expansion Board - by khgoh - 07-26-2016, 02:59 AM
RE: I2C Expansion Board - by MarkHaysHarris777 - 07-26-2016, 07:09 AM
RE: I2C Expansion Board - by DonFL - 07-26-2016, 05:19 AM
RE: I2C Expansion Board - by Artyom - 07-26-2016, 08:51 AM
RE: I2C Expansion Board - by MarkHaysHarris777 - 07-26-2016, 10:52 AM
RE: I2C Expansion Board - by DonFL - 07-26-2016, 09:03 AM
RE: I2C Expansion Board - by Artyom - 07-26-2016, 11:31 AM
RE: I2C Expansion Board - by khgoh - 07-26-2016, 09:17 PM
RE: I2C Expansion Board - by dkryder - 07-27-2016, 12:51 AM
RE: I2C Expansion Board - by pineadmin - 07-27-2016, 01:30 AM
RE: I2C Expansion Board - by Artyom - 07-27-2016, 12:07 AM
I2C Expansion Board - by Artyom - 07-27-2016, 08:16 AM
RE: I2C Expansion Board - by DonFL - 07-27-2016, 09:06 AM
RE: I2C Expansion Board - by xalius - 07-27-2016, 11:06 AM
RE: I2C Expansion Board - by Artyom - 07-27-2016, 11:17 AM
RE: I2C Expansion Board - by dkryder - 07-27-2016, 12:10 PM
RE: I2C Expansion Board - by Artyom - 07-27-2016, 12:20 PM
RE: I2C Expansion Board - by dkryder - 07-27-2016, 05:58 PM
RE: I2C Expansion Board - by martinayotte - 07-27-2016, 12:41 PM
RE: I2C Expansion Board - by xalius - 07-27-2016, 12:49 PM
RE: I2C Expansion Board - by martinayotte - 07-27-2016, 04:54 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 03:44 PM
RE: I2C Expansion Board - by martinayotte - 07-27-2016, 07:19 PM
RE: I2C Expansion Board - by khgoh - 07-27-2016, 09:33 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 09:14 AM
RE: I2C Expansion Board - by DonFL - 07-28-2016, 06:21 AM
RE: I2C Expansion Board - by khgoh - 07-28-2016, 04:28 PM
RE: I2C Expansion Board - by xalius - 07-28-2016, 03:58 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 05:46 PM
RE: I2C Expansion Board - by xalius - 07-28-2016, 06:28 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 07:19 PM
RE: I2C Expansion Board - by Artyom - 07-30-2016, 06:31 AM
RE: I2C Expansion Board - by tllim - 07-30-2016, 06:07 PM
RE: I2C Expansion Board - by AndrewC78 - 08-16-2022, 10:29 AM
  Poll: interest for SPDIF-only POT board? amp 0 3,746 05-01-2019, 11:17 PM
Last Post: amp
  Audio DAC pot board nejec 2 8,625 12-09-2017, 01:43 PM
Last Post: nejec
  Zwave Board: 300, 400 or 500? Lugor 4 11,541 01-10-2017, 08:55 PM
Last Post: Lugor
  Questions. board serial.? bongky youn 8 14,881 09-12-2016, 09:24 AM
Last Post: bongky youn
  My Board Layout Diagram UnixOutlaw 8 17,347 09-09-2016, 02:41 AM
Last Post: pfeerick
  New module: POT board Crispin 25 53,995 07-12-2016, 08:47 PM
Last Post: khgoh
  GPS expansion board stephen fleming 3 7,857 07-06-2016, 11:20 AM
Last Post: xalius
