I2C Expansion Board
I found the problem that cause the I2c communication brake down when installing the I2c POT. The problem is due to the internal pull up feature is not enabled by default on the i2c i/o pin. I manage to come up with a small program that enable the internal pull up for the I2c Pin. You can download it from the wiki page. The archive is included with the source code and the compiled binary (I use ubuntu 20160716-1 image with gcc to compile the code).
You just need to execute the program once (with root access privilege) to enable the internal pull. After that, you can test it out using the i2cdetect to detect the i2c devices.
../KH Goh
I2C Expansion Board - by DonFL - 07-21-2016, 11:15 AM
RE: I2C Expansion Board - by Artyom - 07-21-2016, 12:59 PM
RE: I2C Expansion Board - by DonFL - 07-21-2016, 01:17 PM
RE: I2C Expansion Board - by khgoh - 07-21-2016, 07:16 PM
RE: I2C Expansion Board - by MarkHaysHarris777 - 07-21-2016, 10:34 PM
RE: I2C Expansion Board - by DonFL - 07-22-2016, 12:28 AM
RE: I2C Expansion Board - by khgoh - 07-26-2016, 02:59 AM
RE: I2C Expansion Board - by MarkHaysHarris777 - 07-26-2016, 07:09 AM
RE: I2C Expansion Board - by DonFL - 07-26-2016, 05:19 AM
RE: I2C Expansion Board - by Artyom - 07-26-2016, 08:51 AM
RE: I2C Expansion Board - by MarkHaysHarris777 - 07-26-2016, 10:52 AM
RE: I2C Expansion Board - by DonFL - 07-26-2016, 09:03 AM
RE: I2C Expansion Board - by Artyom - 07-26-2016, 11:31 AM
RE: I2C Expansion Board - by khgoh - 07-26-2016, 09:17 PM
RE: I2C Expansion Board - by dkryder - 07-27-2016, 12:51 AM
RE: I2C Expansion Board - by pineadmin - 07-27-2016, 01:30 AM
RE: I2C Expansion Board - by Artyom - 07-27-2016, 12:07 AM
I2C Expansion Board - by Artyom - 07-27-2016, 08:16 AM
RE: I2C Expansion Board - by DonFL - 07-27-2016, 09:06 AM
RE: I2C Expansion Board - by xalius - 07-27-2016, 11:06 AM
RE: I2C Expansion Board - by Artyom - 07-27-2016, 11:17 AM
RE: I2C Expansion Board - by dkryder - 07-27-2016, 12:10 PM
RE: I2C Expansion Board - by Artyom - 07-27-2016, 12:20 PM
RE: I2C Expansion Board - by dkryder - 07-27-2016, 05:58 PM
RE: I2C Expansion Board - by martinayotte - 07-27-2016, 12:41 PM
RE: I2C Expansion Board - by xalius - 07-27-2016, 12:49 PM
RE: I2C Expansion Board - by martinayotte - 07-27-2016, 04:54 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 03:44 PM
RE: I2C Expansion Board - by martinayotte - 07-27-2016, 07:19 PM
RE: I2C Expansion Board - by khgoh - 07-27-2016, 09:33 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 09:14 AM
RE: I2C Expansion Board - by DonFL - 07-28-2016, 06:21 AM
RE: I2C Expansion Board - by khgoh - 07-28-2016, 04:28 PM
RE: I2C Expansion Board - by xalius - 07-28-2016, 03:58 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 05:46 PM
RE: I2C Expansion Board - by xalius - 07-28-2016, 06:28 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 07:19 PM
RE: I2C Expansion Board - by Artyom - 07-30-2016, 06:31 AM
RE: I2C Expansion Board - by tllim - 07-30-2016, 06:07 PM
RE: I2C Expansion Board - by AndrewC78 - 08-16-2022, 10:29 AM
  Poll: interest for SPDIF-only POT board? amp 0 3,746 05-01-2019, 11:17 PM
Last Post: amp
  Audio DAC pot board nejec 2 8,625 12-09-2017, 01:43 PM
Last Post: nejec
  Zwave Board: 300, 400 or 500? Lugor 4 11,541 01-10-2017, 08:55 PM
Last Post: Lugor
  Questions. board serial.? bongky youn 8 14,881 09-12-2016, 09:24 AM
Last Post: bongky youn
  My Board Layout Diagram UnixOutlaw 8 17,347 09-09-2016, 02:41 AM
Last Post: pfeerick
  New module: POT board Crispin 25 53,995 07-12-2016, 08:47 PM
Last Post: khgoh
  GPS expansion board stephen fleming 3 7,857 07-06-2016, 11:20 AM
Last Post: xalius
